Go to Post I'm a programmer by training and inclination, so my mechanical ideas are sometimes rather, um, loosely constrained by physical reality. - Alan Anderson [more]
Unread 17-01-2009, 21:09
gallo26's Avatar
gallo26 gallo26 is offline
Team 79 Alumni
AKA: Bryan Gallo
FRC #0079 (Team KRUNCH)
gallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to allgallo26 is a name known to all
Send a message via AIM to gallo26
Re: pic: Wheel problem.
Yup! i thought about that... I was a little tired after the first 2 wheels we did. So we might end up doing that for competition. Thanks!
Team 79 Alumni '11- Present
Team 79 Driver '09, '10
Team 79 Senior CAD Designer '09, '10
Team 79 President '09
Team 79 Electrical Sub Team Leader '08, '09
Unread 17-01-2009, 21:15
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
If you tapped the wheels to install screas to hold the hubs, you probably waekended the plastic enough to cause this after running.
As suggested above, #8 screws and nylon insert lock nuts work very well and would save you a lot of time.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 17-01-2009, 22:03
seraphim33's Avatar
seraphim33 seraphim33 is offline
jordan
FRC #2591 (Red Tails)
Team Role: Driver
seraphim33 is just really niceseraphim33 is just really niceseraphim33 is just really niceseraphim33 is just really niceseraphim33 is just really nice
Send a message via Yahoo to seraphim33
Originally Posted by KRUNCH DUDE View Post
we were puttin our wheels together on a test bot and one fell off the table to the floor(a 3ft fall) and cracked the white part of the wheel
2008 Great lakes regional rookie all-star
2008 newton division highest rookie seed
HOW ABOUT THEM REDTAILS?!
ZZZZOOOOOOOOMMMM!!!!!!!!!!
Unread 17-01-2009, 22:14
Originally Posted by gallo26 View Post
It was hard enough to get those screws in there after we tapped the holes.
It shouldn't be that hard to insert screws after tapping. Maybe you didn't tap it correctly?
Unread 17-01-2009, 22:28
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Our wheels are tapped and we haven't had this problem (although, we haven't had a lot of drive time either). How far did your screws go into the wheel? Using longer screws might eliminate this problem.
Unread 17-01-2009, 22:47
KRUNCH DUDE's Avatar
KRUNCH DUDE KRUNCH DUDE is offline
AKA: Erik
FRC #0079 (KRUNCH)
KRUNCH DUDE is a jewel in the roughKRUNCH DUDE is a jewel in the roughKRUNCH DUDE is a jewel in the rough
Send a message via AIM to KRUNCH DUDE
I doubt that tapping the holes could do that much damage also next pictures will be taken with a camera sorry
Unread 17-01-2009, 22:56
blhenze blhenze is offline
Bernie H
FRC #2333 (Sapulpa Chieftain Robotics)
blhenze is an unknown quantity at this point
When I saw that they suggested to tap the holes in the wheel, I did a quick comparison to last year's wheel rim. I strongly recommend using 8-32 1.25" UNC screws with washer, lock washer, and nut. The 8-32s fit perfectly through the holes and provide a much stronger connection to the gear/wheel then a tapped hole with short screws.
Unread 18-01-2009, 04:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Why are people tapping the wheels for #10 hardware?
The specs on the wheels say the six holes should be 3/16", or just barely smaller (.0025") than #10 close fit tolerance. In real life however, it seems that everything on the KoP wheels is about .05" larger than the posted specs. Checking the wheels on calipers reveals the six holes to have a diameter of about .17", which is #8 clearance but is too large for #10 tapping!
#10/32 should be tapped with a .159" (#21 drill) hole, and #10/24 should be tapped with a .1495" (#25 drill) hole. And without reaming the hole larger to #7 drill (.201"), you cannot tap for 1/4-20. I'm halfway amazed you were even able to get threads to stay in after tapping these holes.
Art Dutra IV
世上无难事,只怕有心人.
Unread 18-01-2009, 08:26
Jacob Paikoff's Avatar
Jacob Paikoff Jacob Paikoff is offline
FRC reunion tour
FRC #0079 (Krunch)
Jacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant futureJacob Paikoff has a brilliant future
Because if you look at the directions for the C-Base Chassis on AndyMark it says to tap the wheels for #10.
Team 79, Krunch 2007-2010 Student
Team 2059, The Hitchhikers 2011-2014 College Mentor
Team 5402, The Iron Kings 2015 Mentor
Team 79, Krunch 2016 - Mentor
Unread 18-01-2009, 09:44
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: pic: Wheel problem.
Just to add my 2 cents to the wheel problem, based on my experience with the A/M wheels. Although your picture is not clear, it appears the bearing broke through the hub mount. Last year's wheel had a modification in this area by increasing the length of the webs at this bearing/hub mount, but they still did not fully come up to the outer edge of the bearing race. We felt this was still a weak area, and reinforced this by design. Initially, the first year, we filled the cavity at the hub/webs with a fiberglass resin mix, but still felt it was a weak area. Last year, we did not mount the bearings in the wheel at all. Instead, we bored our sprockets to accept a flanged bearing and made a washer of aluminum on the opposite side of the wheel and did the same. We only used three 10-32 screws though the A/M wheels for lightness, drilling clearance holes through the washer and wheel hub for the 10-32 bolts, and tapped the sprockets and jamb-nutted the bolts (to the sprocket) so they wouldn't loosen. We had zero problems with the A/M wheels last year, and the lateral load on the wheels in Overdrive would appear to be significantly higher than we would expect to see this year. A clearer photo would be helpful showing both sides of the wheel, and I hope this gives you some additional insight as to what may have caused this failure. By the way, we used flanged 7/8" OD x 5/16" or 3/8" ID shielded bearings instead of the 1.125" OD bearings as well. Finally, be cautious on how much you tighten the sprocket bolts, as overtightening is possible and can cause stress cracks to form that are very difficult to see.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 18-01-2009, 09:50
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
One problem with using #8 hardware is that the sprockets have holes that are sized to clear #10 screws, so things are a bit loose.
It would be very helpful to know how long the screws are that you used to hold the sprocket onto the wheel.
Unread 18-01-2009, 10:14
FRC reunion tour
FRC #0079 (Krunch)
Not to discredit anything you said, but I remember we were with you guys during elimination in Atlanta and I seem to remember you guys having a major problem with your wheels where you broke the two middle ones on one side of the drivetrain.
And to answer Squirrel's question we where using 3/4" #10 screws.
Just to let everyone know the side of the wheel in the picture is the side opposite the sprocket, the sprocket side of the wheel wasnt as bad but it was still cracked.
Unread 18-01-2009, 10:18
MrForbes's Avatar
AKA: Jim
I think 3/4" long screws are way too short for this application, the area that the screw goes into is pretty thin. 1-1/4" screws would probably be better.
The damage to the wheel was probably due partly to driving off a bump?
Unread 18-01-2009, 12:17
Hodge1
Just to clarify what happened last year in elims in Atlanta last year had nothing to do with hub disintegration. As a matter of fact, the hubs withstood the defensive attack from a robot that got under our frame with a side hit placing tremendous lateral load on the wheels, breaking the spokes as well as one of our drive chains. If the mods weren't done as outlined, these lateral loads would have disintegrated the hubs. The loads just got transferred to the next weakest link. In any event, the information was presented to help others solve a potential problem with the wheels as shown in the photo. Use or discard the information as you see fit.
Sweat the details
Unread 18-01-2009, 14:04
Wayne Doenges's Avatar
Wayne Doenges Wayne Doenges is offline
We Build Robots......and Careers
AKA: Warthog
FRC #1501 (Team T.H.R.U.S.T.)
Wayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond reputeWayne Doenges has a reputation beyond repute
We routinely fill the voids with epoxy. 30 minute will do. Let cure over night. Works great.
BTW, clean out the voids to remove any mold release that might still be present.
We Build Robots and Careers
World's - #1 seeded in Archimedes, WON Archimedes and made it to Einstein
2016 NC District - Guilford County. #13 seeded, Finalist. Won Quality award.
IN District - Tippecanoe. #4 seeded. Won Innovation in Control award.
IN District - Perry Meridian. #3 seeded. Finalist. Won Excellence in Engineering award.
IN District - State Championship. #1 seeded. Finalist. Won Excellence inn Engineering award.
Autonomous Two wheel problem??? fallen751 Programming 4 11-02-2007 23:07
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: da wheel CD47-Bot Robot Showcase 11 08-02-2004 22:04
