Go to Post Wow I am old. How did that happen? - Paul Copioli [more]
Unread 18-01-2009, 13:57
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: cRIO v7 fails
Originally Posted by Peter H View Post
I updated LabView to the latest configuration. I was unable to update the Driver station; same problem with the USB drive as several other teams reported. I will try other USB drives Tuesday to see if one works.
We recycled cRIO power several times, waiting up to several minutes between.
Since you didn't update the DS, don't bother with the cRIO. It just won't work without the DS update. For us, an old Kingston DataTraveler did the trick, don't forget to reboot the DS after plugging the flash drive and everything should work as intended.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
cRIO fuse??? 20 or 30? mynameisbob Electrical 12 09-01-2009 11:33
Code runs only once, fails on reset roknjohn Programming 7 21-02-2005 20:24
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Camera fails to output anything on serial lines steven114 Electrical 10 18-01-2005 16:12
When all else fails.... ColleenShaver Robot Showcase 5 02-02-2003 01:11
