Go to Post The great thing about liking someone in your robotics team is that they've already seen you at your worst, and you cant shock them with ANYTHING anymore :D - SCROSSLEY-GCEC [more]
Unread 18-01-2009, 12:31
Peter H Peter H is offline
FRC #1606 (Dragons)
Peter H is an unknown quantity at this point
cRIO v7 fails
We connected the cRIO and other components, and ran the benchtop test with no errors. The joysticks control the motors as expected. Then we updated the cRIO firmware with FRC_2009_v7.zip, following section 5.1.2 of the Control System manual, and selecting the LabView option and our IP address. Apparently OK; all messages showed as described in the manual. Now, at power on, the LEDs on the Jaguars blink, and a green LED on the digital sidecar blinks. I loaded LabView on our laptop and selected the RT cRIO Target, Basic Robot Main vi. I selected the Run option, which apparently copied the program to the cRIO OK. The Jaguar LEDs and sidecar LED continued to blink, and we found no response to the joysticks.
What am I doing wrong?
Unread 18-01-2009, 12:50
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: cRIO v7 fails
Have you upgraded the firmware on the Driver's Station, as well as patched LabView and WindRiver to the newest versions of the software? All of this must be done at once.
Unread 18-01-2009, 12:53
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: cRIO v7 fails
You will also need to restart the cRIO (by removing power, waiting a couple seconds, and re-applying power) to make everything work.
Unread 18-01-2009, 12:58
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Re: cRIO v7 fails
Did you update the Driver Station firmware as well? If the LCD reads *** OTB *** on the last line, then it's not gonna work with the updated cRIO image.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 18-01-2009, 13:02
FRC #1606 (Dragons)
Re: cRIO v7 fails
I updated LabView to the latest configuration. I was unable to update the Driver station; same problem with the USB drive as several other teams reported. I will try other USB drives Tuesday to see if one works.
We recycled cRIO power several times, waiting up to several minutes between.
Unread 18-01-2009, 13:57
Manoel's Avatar
Re: cRIO v7 fails
Since you didn't update the DS, don't bother with the cRIO. It just won't work without the DS update. For us, an old Kingston DataTraveler did the trick, don't forget to reboot the DS after plugging the flash drive and everything should work as intended.
Brazilian Machine
Team # 383
Unread 18-01-2009, 14:03
Re: cRIO v7 fails
It is times like these I wish FIRST had an official wiki where people could aggregate knowledge about what works and what doesn't work. Someday...
Unread 18-01-2009, 14:26
Carpe diem
Re: cRIO v7 fails
Me too! I used a 16GB Kingston DataTraveler. Worked great.
cRIO fuse??? 20 or 30? mynameisbob Electrical 12 09-01-2009 11:33
Code runs only once, fails on reset roknjohn Programming 7 21-02-2005 20:24
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Camera fails to output anything on serial lines steven114 Electrical 10 18-01-2005 16:12
When all else fails.... ColleenShaver Robot Showcase 5 02-02-2003 01:11
