Go to Post some people sing in the shower........i pretend to be an emcee at championships......:cool: - BanksKid [more]
Unread 18-01-2009, 14:38
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Moniter Motor Speed
My team is planning to create a shooter similar to this one, with 1 CIM motor directly driving the bottom wheels. The goal is for the camera to detect distance from the trailer and then automatically set the motor speed.
Do you think we'll need to set motor rpm using a PID loop, or will just setting the PWM output be enough?
If you think we do need to monitor the speed, what sensor should we use? Geer-tooth counter? Encoder? Pots? How are they mounted? Do you know what part number will work with the WPI Libraries?
Thanks in advance!
Unread 18-01-2009, 14:45
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Re: Moniter Motor Speed
I would recomend a PID loop if you want to be changing the motor's speed, although they do take time to tune. Most encoders should work with WPI providing you set them up right. However, if you are changing the speed you will also need to take into account the inertia of the wheels.
Controlling motor speed WGRAY Programming 9 16-02-2009 22:50
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
Motor Speed AHepperla Programming 6 25-01-2008 21:39
Motor speed HellBoy Programming 2 05-02-2007 10:41
Drill motor true speed? archiver 2001 0 23-06-2002 23:58
