Go to Post It's official: we've run out of things to talk about. - Jessica Boucher [more]
Unread 18-01-2009, 14:08
easponge's Avatar
easponge easponge is offline
You're off the team!
AKA: Betsy Soukup
FRC #0694 (StuyPulse)
easponge is an unknown quantity at this point
Reason for jaguar short?
Hey CD,
Our team recently attended a programming workshop that required bringing the entire control system to a new location (no small feat).
During the workshop, the system started losing power and the power source read that 5.7 amps were being drawn. After disconnecting everything, we found that there was a shorted Jaguar attached to a broken Wago connector.
Is there a reason why the broken connector would have caused a short/are the two problems even related?
Where can we purchase a replacement 40amp connector for the power distribution block?
Do CIMs need to run on Jaguars this year or can we legally replace it with an 884 victor?
Thanks,
-Betsy
Unread 18-01-2009, 14:20
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Reason for jaguar short?
Don't quote me, but somewhere I remember reading you can use the victors. I think it might have been on that flow chart that came with the control system, so check that out.
Unread 18-01-2009, 14:49
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
You can use Victor 884s or Jaguars interchangably, from what I can understand.
Unread 18-01-2009, 14:52
AKA: Brandon Liatys
I just watched the "your in control" vid from the kickoff, and it says you can use either so I guess that would be a yes.
http://www.usfirst.org/community/frc...nt.aspx?id=418
Unread 18-01-2009, 15:09
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
You could download
http://usfirst.org/community/frc/content.aspx?id=452
and read the rules...section 8 answers most of these questions, but it wouldn't hurt to read it all.
Also don't expect to be able to repair the distribution board...but you can buy a new one.
http://andymark.biz/am-0265.html
(not cheap)
Newton Final 2: Reason for disqualification ham90mack Championship Event 17 10-03-2008 23:38
FIRST - Reason for existance Steve W General Forum 39 20-05-2004 07:19
Can't log out correctly for some reason Adam Y. CD Forum Support 2 12-05-2004 21:19
Short fictional story: 'For Real' archiver 2000 1 24-06-2002 00:03
Possible Rule change for Flordia? (Please) and the reason for more seeding rounds. archiver 1999 6 23-06-2002 22:09
