Go to Post You know you're addicted to FIRST when you text your mentors more than your friends from school. - LindsayC [more]
Unread 18-01-2009, 15:14
DtD's Avatar
DtD DtD is offline
I hope the watchdog starves!
AKA: Pathogen David
FRC #2410 (The Metal Mustangs (Merged from 2334, Hazmat Robotics))
DtD will become famous soon enoughDtD will become famous soon enough
Code Declaration Window - Check Team in Code
I normally use Microsoft Visual Studio outside of robotics, and constantly use the "Code Declaration Window" and I love it. I was wondering if anyone knew of something similar in WindRiver (or Eclipse...)
I found something similar on the internet, but it didn't tell me how to activate it. It just told me it was there and showed a pretty screenshot...
Also, does anyone know how to check the team color in C++? I saw sombody post it earlier, but I can't seem to find it again for the life of me, and I've tried looking through the WPILib docs too... (Including regenerated ones I generated)
~DtD
May I get a steering wheel and pedal code check? windell747 Programming 1 11-02-2008 08:43
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Fix-it window and dashboard code changes David Brinza Programming 3 28-01-2005 01:00
