Go to Post There is a big difference between "we have not been able to figure out how to do it." and "it's impossible" or "don't even bother." Let's be constructive not discouraging. - PVCMike [more]
Unread 17-01-2009, 19:09
team877's Avatar
team877 team877 is offline
FRC #0877 (Cub Robotics)
team877 is an unknown quantity at this point
Re: Labview Joystick Buttons...
thank you so much
Unread 17-01-2009, 19:11
Mikesername's Avatar
Mikesername Mikesername is offline
meh.
AKA: Mike Dame
FRC #3044 (Team 0xBE4)
Mikesername is an unknown quantity at this point
Send a message via AIM to Mikesername
I can't wire it from the boolean to 0,1 to the close. I have drive close on the outside of my main loop, and it's wired to the drivedevref global variable, but when I try to wire to it the wire goes dotted. When I try to make another drive close inside the loop and wire to it I get the same problem
Edit: Or is it not possible to set it to drive close? I just wanted to do that so I could test the button input at our next meeting...
[ ballston spa robotics | www.team3044.com | team BE4]
Unread 17-01-2009, 19:18
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
The only thing that needs to be sent to the Close VI is the DevRef wire, which is the pink wire that comes out of the "Open Jaguar" or "Open 2 Motor", etc, VI.
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 17-01-2009, 19:42
team877's Avatar
i can get the relay to turn off but not able to engage it...so when I press the button the relay shuts off
Unread 17-01-2009, 19:46
TotalChaos's Avatar
AKA: Austin
So you want to press a button to turn the relay on, release the button and do whatever else you need then be able to hit the same button to turn it off?
Or maybe I'm still misunderstanding you?
- Austin
Unread 17-01-2009, 21:29
meh.
AKA: Mike Dame
What about pressing a button to turn on the compressor?
Then pressing another one to turn it off?
Sorry if I'm derailing the thread, but I figured it was still somewhat related so instead of starting [another] thread on joystick buttons...
Unread 18-01-2009, 14:37
team877's Avatar
I don't want to turn the relay on and off. I want it always on. But i want it to either have a forward polarity or a reverse polarity. (indicated by green for forward and red for reverse on the spike itself) Can you explain to me how to do this?
Unread 18-01-2009, 14:47
TotalChaos's Avatar
AKA: Austin
Oh, ok, I think I'm getting a better understanding.. Are you trying to make one button that toggles between forward and reverse, or are you trying to do one button for forward and another for reverse?
- Austin
EDIT - Or forward when held down, reversed when unpressed?
Unread 18-01-2009, 14:50
team877's Avatar
I would like to know how to do both!!! haha
Unread 18-01-2009, 15:02
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
You could use a case structure attached to the button, or one of those boolean selectors with the question mark.
For the case structure, you would just put the relay function in the C/S, then wire a constant to the input.
The boolean selector would be similar but smaller and simpler, and if you know what Im talking about, I'd use it.
Go here for how to use the relay function (as well as any other first function):http://decibel.ni.com/content/docs/DOC-2631
If you right click on the input node and select create->constant it will put an enum there with forward and reverse settings. Because it is an enum, the three states will be 0, 1, 2 for forward, reverse and off, I think (in no particular order, check the enum for the real values).
Hope that helps get you on your way. That should be enough to do both of those scenarios.
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 18-01-2009, 15:29
team877's Avatar
A picture of this would be much appreciated
Unread 18-01-2009, 16:33
team877's Avatar
Can anyone just make one of these programs and make a printscreen.
I'm desperate to figure this out and so far i've been unsuccessful.
I need to use a joystick button to engage a relay forward, and reverse, and off....Please help!
Unread 18-01-2009, 16:38
ShotgunNinja's Avatar
ShotgunNinja ShotgunNinja is offline
Programming Mentor, FRC 4247
AKA: Nicholas Iannone
FRC #4247 (CougarBOTS)
ShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the roughShotgunNinja is a jewel in the rough
Hey all, a bit late, but I have made a simple VI for retrieving a single button's boolean state based on it's enumerated value. It hooks up just like the Get Axis sub-VI, but with an Unsigned Byte (8-bit) input hook for a button enumerator control.
Here's a screenshot:
Here's a copy of the VI:
Team #2970 Alum
Team #1652 Alum
2006: School Mascot for Team 1652
2007-2008: Programmer for Team 1652 (Robot Mafia)
2009: Programmer on Team 1652 (Robot Mafia), Programmer on Team 2970 (eSchool eBots)
2010-2016: Volunteer, Wisconsin Regional
2017: Programming Mentor, FRC 4247 (CougarBOTS, Obama SCTE, Milwaukee, WI)
Unread 18-01-2009, 17:14
TotalChaos's Avatar
AKA: Austin
Ok, I whipped up something as an example. I haven't had a chance to test this code on our base so there's no guarantees, but as far as the general idea goes I think its a good example.
Usually I would just post a screenshot and explain in the post, but since there's cases inside of cases I wouldn't be able to show you everything without a screenshot for every possible combination, so Instead you can just download the code. (I'll attatch it to this post) I have comments in the code that explain everything I did and why. I don't know that this is the best or most efficient way to do what you are trying to do, but it is one solution. If you have and questions about the code feel free to ask! And if you find any errors please let me know!
- Austin
Unread 18-01-2009, 18:06
team877's Avatar
this is what i have so far if anyone can build from this that would be absolutely amazing
How do you program joystick buttons in LabVIEW? darkpheonix NI LabVIEW 10 13-04-2014 10:20
Buttons on a Attack 3 Joystick useing LABView morg102 NI LabVIEW 14 02-02-2010 23:28
buttons in LabView Pneumaticsman NI LabVIEW 4 12-01-2009 18:14
Buttons to Pins on Joystick yarb65 Electrical 1 24-08-2007 20:39
Assigning Joystick buttons.... archiver 2001 5 24-06-2002 00:59
