Go to Post I've come to the conclusion that the only way Pat's awesomeness can be explained is.... Pat Fairbank is a cookie. - Jonathan Norris [more]
Unread 18-01-2009, 16:52
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Speed of axis camera
Has anyone else noticed that FindTwoColors() takes a really long time? I noticed the camera servo loop was running slowly so I tested the time FindTwoColors() takes and it is about .34 seconds. Thinking it might be a problem with my code, I ran their default code and FindTwoColors() still took .34 seconds. has anyone else encountered this problem?
Unread 18-01-2009, 16:56
Re: Speed of axis camera
If the example doesn't set the resolution, your camera could be set to 640x480. At that resolution, the decoding of the jpg, and the shear number of pixels to process will limit processing to something like four fps.
Greg McKaskle
Unread 18-01-2009, 17:06
gorillamonky gorillamonky is offline
FRC #0696
gorillamonky is an unknown quantity at this point
Greg McKaskle
agreed, your resolution can be bulcox and you will still find the colors, try setting your resolution to the lowest you can find.
you also don't need to find multiple colors, finding one is fine, however, you should find the two colors as one color if at all possible so you can differentiate between teams
ie, find the setting for red on top as one color, named rog
and the setting for green on top as one color, named gor
Unread 18-01-2009, 17:59
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Greg McKaskle
By default the TwoColorDemo code sets it to 320*240 @ 15fps. You can change the FPS setting on line 100 of TwoColorDemo.cpp, and you can change the resolution at line 131 of TwoColorDemo.cpp.
The resolution choices are k640x480, k320x240, k160x120.
I also had the same issue. I haven't had time to experiment with resolution yet, but I suspect that it will help.
Eric Haskins KC9JVH
Unread 18-01-2009, 18:14
nickmagus's Avatar
AKA: Nick Clayton
I have already done some experimentation with the resolution. It significantly improves the speed of the loop (about 3.3 times faster which is about right since it has 1/4 as many pixels to look through) but the autonomous still only runs at 10 hz (not nearly fast enough). With some further experimentation i found that the frcColorThreshold() appears to be the slowest link. Threading is a possible solution but it seems that that would not help because threading cant increase the processor speed of the cRio. it might not speed up the camera but it would keep it from interfering with the rest of the code.
Unread 18-01-2009, 18:20
Good summary about threading. Many people fall for the -- more threads results in faster execution trap. Having the camera run at 10Hz may be reasonable, but you don't want it to slow everything else down. Give the tasks or threads a shot. It certainly helped the LV stuff to be in an independent loop.
Greg McKaskle
Unread 18-01-2009, 18:25
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
try setting the res to 160 by 120, and do processing at 15fps.
You can also do a bit of code modifying to only threshold one color, which would significantly increase speed.
what i would think about doing is thresholding one color, then doing the particle analysis, and then doing a linear search through all the returned particles;
if the color patch is big enough, search for the color from the original image that you would expect to be below the color patch (red on green, or green/red) using a 3 point match or more if necessary.
im pretty sure that would at least double the speed.
since thresholding seems to be the slowest operation, perhaps modifying the thresholding algorithm to optimize it for the cRIO's processor might yield some benefit (though it probably already is... and that would be sad)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Connecting Axis Camera Sauce Programming 8 18-01-2009 20:08
Model of Axis Camera Bochek CAD 2 18-01-2009 17:50
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Program Axis Camera in c++ excel2474 Programming 5 22-12-2008 17:14
axis camera - problem s0crates FRC Control System 11 16-12-2008 09:34
