Go to Post I'm gonna go back to my corner and write some more code... - Kevin Watson [more]
Unread 18-01-2009, 17:27
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: cRIO has no code
When you debug code of the robot it is not stored permanently, so when you reset it there is no user code. I'm guessing this is what happened.
Make sure that you've read and understand pages 20-26 of the C/C++ Programming Guide.
You may be having a different issue, but without more detail about the error message I can't know.
The battery voltage monitoring and reporting code is located in the WPILib code, so unless you're running a modified version then it should report a voltage. Even if you broke that part of the code it would report 0.0 volts not NO CODE.
Eric Haskins KC9JVH
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
cRIO - motor controller code (esp. victor) ericand Programming 8 06-12-2008 22:09
Team 166 Has Open Sourced Its Code platypus Programming 13 09-02-2008 16:03
Does anyone has code for accelerometer? sjung9442 Programming 2 30-01-2006 21:37
Has anyone craked the code yet Jeremy General Forum 2 09-01-2004 14:12
