Go to Post Yes, machining a dog profile into a steel sprocket on a manual mill was an experience filled with pain and regret. - Joe G. [more]
Unread 05-01-2009, 07:28
MachineSMMC MachineSMMC is offline
FRC #3026
MachineSMMC is an unknown quantity at this point
IGES File of teh KOP
Would somebody be interested in exporting the entire KOP as an IGES files so I can bring it into another software?
Thanks
Chris Tellers
Team #3026
The Berzerkisatni Knights
Unread 08-01-2009, 15:31
FRC #3026
Re: IGES File of teh KOP
I am using SolidWorks and would love for somebody to export the KOP as an IGES file so I can import them into SolidWorks.
SolidWorks is not able to import the Inventor or the Pro-E Files.
Thanks
Chris Tellers
Team #3026
Orange Crush
Unread 15-01-2009, 15:43
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
I am working on it - Here is the slick wheel from AndyMark. I cant open the Inventor or ProE files so I need to get these from the manufacturers and convert. The process is slow. Marie
http://www.3dcontentcentral.com/part...atalogid=171#0
Unread 16-01-2009, 09:01
Thanks to Andy and Mark I was able to finish the AM Long Frame last night
http://www.3dcontentcentral.com/secu...d=171&id=13547
You can download it in IGES, SolidWorks 2007, 2008, Autocad or what ever else.
Thank you too for Felix adding the model for the orital ball.
Marie
Unread 18-01-2009, 04:18
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
Is anyone working on drafting the electronics in Solidworks?
If no one is working on it, i suppose i could start to work on it and post it on the 3dcontent site.... But, i was hoping someone already had some available...
someone did draft the gaming router, and it looks pretty nice.
I use SolidWorks 2007 SE BTW...
Unread 18-01-2009, 11:53
Here is thelink to the NI Controller on 3Dcontentcentral.com
I don't know the electronics in the kit. Do you have part numbers and manufacturers? I might be able to call them on Monday if they are SolidWorks customers and ask for files on your behalf.
I used a new technology in SolidWorks to save the NI Controller. I took the step model file from NI and confirmed with First CAD Library and then saved the assembly as a SolidWorks part. It is a single part with all extracted faces - much lighter in file size.
http://www.3dcontentcentral.com/part...&catalogid=171
Marie
Unread 18-01-2009, 13:48
keen101's Avatar
Ubuntu Linux User
Thanks, the cRIO is one of the things I've already obtained. I'm mostly trying to get the power distribution board, and the digital sidecar. http://andymark.biz/09electronics.html
I think they were made by Diversified systems.
I also think they are already drafted with autodesk inventor, but i don't have inventor currently installed. https://firstbasefrc.autodesk.com/?nd=kitofparts.
also trying to get the Axis camera and perhaps the robot signal light.
this diagram might help a little. http://usfirst.org/uploadedFiles/200...%20diargam.pdf
Unread 18-01-2009, 16:16
I need a step file to reverse engineer it back to SolidWork format - funny I dont have a copy of Inventor either. Once in SolidWorks format, I can then post it in all file formats. Maybe some one will post tonight - if not, I will do the research for you tomorrow.
Marie
Unread 18-01-2009, 17:39
Keen
There are some amazing SolidWorks users out there that are helping you out.
Here is the link to the Digital Side Car by TVHS Robotics - great job.
http://www.3dcontentcentral.com/part...catalogid=171#
Marie
Unread 18-01-2009, 17:51
Keen
http://www.3dcontentcentral.com/secu...d=171&id=13579
Camera Bracket is by Andrew Bates -
For those that contribute to 3dcontentcentral from Jan 18 - Jan 25, 2009, send me a private email with your address and I will send you a SolidWorks Tshirt. Thankyou for helping out all FIRST users.
Marie
Unread 19-01-2009, 16:22
Here it the link for the camera.
I merged all the components into one part. It is alot smaller in file size.
Thank you Brandon.
Marie
Unread 20-01-2009, 17:04
I am not certain if I have all the electronics parts posted on www.3dcontentcentral.com in all file format. Take a look and let me know.
Also, let me know more of the parts you need. Customers have been emailing me files and I just put them up.
Marie
Unread 21-01-2009, 14:23
keen101's Avatar
Ubuntu Linux User
The Robot Signal Light has now been uploaded on www.3dcontentcentral.com. I think most of the electronics have been uploaded by now. There might be a few stragglers like the encoders and stuff but most of it seems to be available now. Thanks for everyone's hard work.
http://www.3dcontentcentral.com/Down...d=171&id=13657
Unread 21-01-2009, 14:41
Brandon Holley's Avatar
Brandon Holley Brandon Holley is online now
Thank you Brandon.
Marie
Anytime Marie...the NUTRONs are glad to be of service to Solidworks, because Solidworks is AMAZING!
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 22-01-2009, 20:16
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Can you guys do the drivers station and modems and stuff? If its not to much to ask the joystick would be sweet also
IGES and STP file modification TomBW CAD 3 31-01-2008 15:11
Slow down teh motors! brennerator Programming 21 18-01-2007 23:30
RED SOX FOR TEH WIN!!! Heretic121 Chit-Chat 56 28-10-2004 23:00
Opinions of teh TV feed Wetzel Chit-Chat 4 29-04-2002 00:46
teh funnah Zeinin Chit-Chat 1 15-04-2002 15:02
