Go to Post My nephew...loves FIRST. He wants to be an X-Cat but since he lives in Atlanta and that's a heck of a long commute for meetings I told him he probably should strive to be the next best thing: a CircuitRunner. - Koko Ed [more]
Unread 18-01-2009, 20:25
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Mounting Sprockets to the Rover Wheels
Hey,
So I was mounting some AndyMark aluminum sprockets to the rover wheels and I noticed that the holes in the wheels are smaller than those in the sprockets. How have other teams been dealing with this? I ended up using machine screws that fit through the wheel mounting holes, but because they're smaller than the holes on the sprocket, it shifts around.
Any suggestions?
Mens et Manus
Unread 18-01-2009, 20:29
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: Mounting Sprockets to the Rover Wheels
we just gave them a little tap with the rubber mallet
8/32 bolts with lock nuts and locktite
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 18-01-2009, 20:34
Matt382 Matt382 is offline
Driver/Drivetrain Subteam Leader
FRC #1816 (The Green Machine)
Team Role: Driver
Matt382 has a spectacular aura aboutMatt382 has a spectacular aura aboutMatt382 has a spectacular aura about
Someone in this thread said that locktite dissolved the plastic on the wheels. I would not recommend using lockite in that case. We decided right away that tapping the holes and screwing steel bolts into plastic was not a good idea (even though it was suggested in the intructions for putting the chassis together) so we drilled the holes out bigger and got longer bolts and bolted the sprockets all the way through with some nylon lock nuts on the other side.
Unread 18-01-2009, 20:38
gorrilla's Avatar
AKA: adam spears
locktite does NOT dissolve plastic at all
Adam Spears
Unread 18-01-2009, 20:41
I haven't seen it happen, but there have been many, many reports that locktited plastic parts break.
I know my team (used to) simply tap the holes of the AM wheels and put the screws in.
Unread 18-01-2009, 20:43
gorrilla's Avatar
AKA: adam spears
from the locktite website
"Threadlockers should only be used on metal-to-metal applications, because the Threadlocker turns into a plastic-like substance."
which is probobly the cause.....
Adam Spears
Unread 18-01-2009, 20:46
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
The holes are intentionally small. AndyMark included instructions for tapping and connecting the sprockets to the wheels in the KOP. These instructions are available via a video at the AM website here: http://lib.store.yahoo.net/lib/yhst-.../AM09WNick.mp4
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 18-01-2009, 20:48
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
This is somewhat incorrect.
Depending on the type of loctite and the type of plastic it can craze and crack plastics. The general suggestion is to test the loctite product on a small, non critical, portion of the plastic to see if there is a reaction.
And if you don't believe me, try Loctite 496 on a piece of polycarbonate
___________________
- Tennyson, Ulysses
Unread 18-01-2009, 20:50
gorrilla's Avatar
AKA: adam spears
locktite meaning, threadlocker blue,green and red....
Adam Spears
Unread 18-01-2009, 21:03
Yes, that sort of thing. Try it first on a non-critical area.
Unread 18-01-2009, 21:06
gorrilla's Avatar
AKA: adam spears
we've always used it, its kinda too late now
i doubt it could though,
and not just on the wheels......
Adam Spears
Unread 18-01-2009, 21:59
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Well, I hate to contradict you, but 811 unfortunately knows better.
"It's NOT Just A Robot Thing!"
Unread 18-01-2009, 22:32
gorrilla's Avatar
AKA: adam spears
i read this, it seems they just poured it in the holes?
if it was the blue threadlocker, then alot of people are in for some troblue
and we put our everything together with it
maybe thats why it says to use it on only metal to metal applications
i still doubt this though,
Adam Spears
Unread 18-01-2009, 23:06
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
Follow the instructions on Andy Marks Website, it explains what size screw to use, and how to tap the holes on the wheels!
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 18-01-2009, 23:14
ryoung52 ryoung52 is offline
FRC #2063
ryoung52 is an unknown quantity at this point
We put a 10-32 tap into the old DeWalt cordless and power tapped the holes in the wheel. It seemed to work fine. Then I started worrying about someone over tightening the screws and stripping the threads. We went ahead and drilled clearance holes and put lock nuts on.
Press release: Nypro makes the rover wheels! Elgin Clock Kit & Additional Hardware 1 12-01-2009 12:01
Rover Wheels neoshaakti Kit & Additional Hardware 11 09-01-2009 14:34
Cost of Rover Wheels Boco Gear General Forum 3 08-01-2009 16:10
Mounting two output sprockets on andyMark :confused: EduardoVemny Motors 5 10-01-2008 21:37
mounting the wheels Stormhammer Technical Discussion 8 28-01-2005 14:41
