Go to Post It is a difficult balancing act - we're engineers because we like to solve problems, and to take a step back and let someone else solve it, with what may be a poorer solution, is darn hard. - DonRotolo [more]
Unread 18-01-2009, 20:29
radau radau is offline
radau is an unknown quantity at this point
Wind River won't start
I'm having trouble with Wind River Workbench. When I start it, the splash shows but after a few seconds it'll disappear and the workbench won't start. I've tried reinstalling it but the problem continues. It's on Windows XP, and I've got Java 1.6 installed.
thanks for any help
also, I've got Eclipse Ganymede and it works fine.
Unread 18-01-2009, 21:17
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Re: Wind River won't start
Check to see if there is a wind river process running in the task manager. It could be running but not showing up for some reason.
Unread 18-01-2009, 21:47
I can see the process start, but then it simply dies and disappears from the process list. Does anyone know if Wind River has any error log? I've tried running the executable from the command prompt but it doesn't print anything (useless!)...
Unread 19-01-2009, 12:27
I've reinstalled a few times now. No luck :|. Anyone?
Unread 19-01-2009, 12:40
What stupid software...
The workspace can ONLY be C:\WindRiver\workspace
If you f*ck this up like I did, just delete the folder C:\Documents and Settings\Username\.workbench-0000
Unread 19-01-2009, 13:22
Last post; a list of grievances.
  1. MUST use C:\WindRiver as install path.
  2. MUST use C:\WindRiver\workspace as workspace path.
  3. No Wind River-specific error logging.
  4. Installer takes forever... 30+ minutes at LEAST, for only the workbench!
  5. Installer leaves a ton of junk all over the place.
  6. Uninstaller leaves a ton of junk all over the place.
  7. Licensing deal is confusing; in fact the entire install process is confusing. Mess it up even slightly and the install is botched.
  8. Severe lack of documentation & support. Not asking for a lot of support; a simple message board would be nice, but one is nowhere to be found!
What a gorramn joke!
Unread 19-01-2009, 23:09
neutrino15's Avatar
neutrino15 neutrino15 is offline
plɹoʍ ollǝɥ
AKA: Jordan Perr
FRC #0694 (Stuypulse)
neutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really niceneutrino15 is just really nice
This happened to me too. I would also get a stack overflow error.
My solution was creating a new workspace.. That is, moving the /workspace directory to the desktop, creating a new one, then re-importing everything from desktop/workspace using windriver's import function.
Uninstall Wind River Lord_Jeremy C/C++ 0 15-01-2009 15:56
SVN wind river Mr.Macdonald C/C++ 3 13-01-2009 12:40
build in wind river Pneumaticsman C/C++ 3 12-01-2009 15:54
Wind River Help BenB Programming 3 02-01-2009 21:42
Open Wind River excel2474 Programming 12 31-12-2008 17:36
