Go to Post Don'tcha love technology? :p - Cory [more]
Unread 15-01-2009, 21:35
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Different type of solenoid
In the past, there have been SMC solenoids in the KOP that connected to both ends of the cylinders and to the air supply. They pressurized one end of the cylinder and vented the other, and stayed in the set position until shifted.
I am looking for a type of solenoid that functions similarly, but when no voltage is applied to either side, BOTH ends of the cylinder are vented to the atmosphere. Problem is, I don't know what this would be called, or even if it exists. Can anyone help me?
Unread 18-01-2009, 20:52
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Different type of solenoid
Sounds like what you want is a 3-position EXHAUST center. So when there is not voltage on the coil, the cylinder can move freely.
If you want the cylinder to freeze in mid stroke, this would be a 3-position CLOSED center.
Use the part configuration on SMC's website here.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Using 2 different keyangs Mikhail_Pham Motors 1 01-02-2008 13:43
A different perspective? Perhaps? Rich Kressly General Forum 10 18-04-2007 19:44
Different Divisions Won nparikh Championship Event 11 08-04-2007 12:05
Field Location of Type-0 and Type-1 IR Signals Travis Hoffman General Forum 3 27-02-2004 07:58
different type of balancing, which one do you like better? archiver 2001 2 24-06-2002 02:33
