Go to Post We also have a " big daddy" hand riveter. In my estimation one could have assembled the George Washington bridge with it. - DonRotolo [more]
Unread 18-01-2009, 21:18
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
User code won't download/run-possible causes?
Hoping someone can shed some light on this,
Today we were trying to download our program to the cRio, and were unable to get it either to download or to run(we're not 100% sure where the problem lies). Basically, whenever we use the "deploy" option in FIRST downloader, the progress bar just flashes on the screen, and when we reboot the cRio it does nothing and we get a "no code" warning. The odd thing is that using the "undeploy" option doesn't generate an error, so the cRio thinks it has something loaded. Additionally, we can download the example programs and they work fine. START_ROBOT_CLASS is calling our frcv1 class, and the network connection works fine.
Based on the testing we've done, we think that either
  1. The build specification is wrong, since our program is showing up as "PPC32diab", but the example shows up as "PPC32gnu"
  2. There's some other option that we have to set in order to get the program to run on startup(other than the START_ROBOT_CLASS one)
  3. FIRST downloader doesn't like our binary and is failing silently
Does anyone have any ideas on what might be the most likely, or something else that might be going wrong?
Get yer robot source code here!
Unread 18-01-2009, 21:23
360skier 360skier is offline
RTFM!!
AKA: Eric A.
FRC #1334 (Red Devils)
360skier is an unknown quantity at this point
Re: User code won't download/run-possible causes?
The only other thing I can think of is that your robot class needs to inherit either SimpleRobot or IterativeRobot, but other than that there shouldn't be any other steps. Perhaps WindRiver didn't install correctly?
Unread 20-01-2009, 22:12
Hacker
My class is:
class frcv1 : public IterativeRobot
Which I have 5 nines of confidence is right. Does anyone know if there's some other option that has to be set to get code to run on startup?
Unread 21-01-2009, 11:00
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Hook up to the serial console and see what is happening as the system boots. You will get helpful messages as your program is attempting to load.
Also, your issue #1 is suspect. It should be PPC32gnu.
I'd suggest making a new project in windriver starting from the simple robot example, as explained in the control system docs. Nuke the example source code file and copy in your sources. Build the project. This should rule out anything wrong in the project build settings.
If that works, simply rename the project to a name of your choice.
Oh, and if you take this route, be sure to update the FIRST downloader settings (Window->Preferences) to point to the NEW binary in the NEW project. It will not update automatically and you'll just be downloading your old project build.
[Windriver] Getting error on run: Download Failed JHale C/C++ 4 15-01-2009 07:42
printf causes programs to not run jasonpeinko Programming 6 17-01-2008 18:54
Won't Download! diaperrash89 Programming 4 25-10-2007 23:02
2005 default code won't compile Robby Programming 22 04-02-2005 18:21
user code to default code phoenixomega001 Programming 5 09-01-2005 00:09
