Go to Post FIRST has set me on a completely different path in life. And I'm all the better for it. - Vincent Chan [more]
Unread 18-01-2009, 21:47
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Wiring a potentiometer to the Analog Breakout
So we have some shiny new potentiometers that we would like to use on our robot this year but I don't have any idea how to wire them to the Analog Breakout. Specifically I would like to know which connector on the potentiometer goes to which pin on the Analog Breakout.
Here is a pic of the potentiometer
and here is a link to the data sheet...
https://www.alliedelec.com/Images/Pr...OL_9700061.PDF
Any help you can give this programmer mentor posing as an electrical mentor would be greatly appreciated.
Thanks
Unread 18-01-2009, 22:01
Re: Wiring a potentiometer to the Analog Breakout
Page 24 of http://usfirst.org/uploadedFiles/3-F...s-Rev-0-5a.pdf
For your vishay pots, the wiper is pin 2, and the other two pins are 1 and 3.
Last edited by EricVanWyk : 18-01-2009 at 22:05. Reason: Clarify that the pin out stated is on the pot end, not on the breakout end.
Unread 18-01-2009, 22:05
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Oh man, ADD boy here. I looked at that manual but didn't make it past page 21.
Thanks, I appreciate your help
Unread 19-01-2009, 00:46
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
We use pots like that. Our solder didn't like sticking to the pins very well, so we gobbed lots of solder on there and covered it with silicone to make sure nothing moved.
Just in case you were having trouble.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 19-01-2009, 07:42
Josh,
With this particular type of solder device, you must be careful to heat both the wire and the solder terminal before adding solder to the joint. Also be sure that the wire is tightly wound around the terminal before soldering. A good soldered connection is a good mechanical connection first.
If you first wire this up for a sensor and it would be more convenient for your programming to reverse it's operation just switch the wires on terminals 1 & 3.
Unread 19-01-2009, 07:50
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Be VERY careful to wire the moving wiper to the signal pin on the Analog Breakout. If you do wire the wiper to either 5V or GND, you will short the power supply at one of the extremes. The power supply on the breakout should survive this but it will become very warm and all of the your sensors will lose power until the short is removed. Depending on the wiper and wire capability, you might even fry the wire and/or wiper.
Russ
Unread 19-01-2009, 12:49
Josh,
Hmm. Thanks for the tip.
Analog Breakout for sale? DarKCroNo FRC Control System 1 05-01-2009 16:39
Wiring analog breakout? excel2474 Electrical 5 31-12-2008 17:30
Pneumatic breakout question. IndySam FRC Control System 5 23-12-2008 17:10
5 Amp Fuses for Analog Breakout & Solenoid Breakout finman Electrical 3 10-12-2008 11:59
Help wiring potentiometer-to-Analog port kylehager Electrical 4 17-01-2008 17:28
