Go to Post Robotic Football now thats something I would build 6 weeks for. - Nikkocharger [more]
Unread 18-01-2009, 22:37
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
AM Planetary Gearbox (removing the fisher price gear/buying one without a gear)
For the AM Planetary gearbox, you need to use a fisher price motor without a gear on it and then press the AM one on. The motors in the KOP have other gears on the already. Do teams pull these off somehow? Is there a place to find the fisher price without a gear on it? I looked at the FIRST documentation for where to buy extras of the KOP, and they don't list where to get the motor.
Mens et Manus
Unread 18-01-2009, 22:40
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: AM Planetary Gearbox (removing the fisher price gear/buying one without a gear)
the FP motor?
like the one with the black plastic gearbox on it?
i dont think it comes attached this year(to the plastic gearbox)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 18-01-2009, 22:43
Originally Posted by gorrilla View Post
the FP motor?
He's talking about the pinion, not the gearbox.
Unread 18-01-2009, 22:44
gorrilla's Avatar
AKA: adam spears
yeah i just realized that
should be able to pop it off somehow....
Adam Spears
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
I'm not near my KOP at the moment, but I'm 99 percent sure that ours came attached.
Mens et Manus
Unread 18-01-2009, 22:46
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Search this site for various ways to remove the pinion gear. You need to be very careful or you will trash the shaft and/or bearings.
We dremel a notch and then whack the pinion with a cold chisel. Cold chisel alone will work if you have a big enough hammer.
I believe that Andy Mark was supposed to be a source for the motors this year, probably with the pinion attached. I also believe that the entire assembly (but not the motor alone) can be ordered as a fisher price replacement part.
Beware - only the motor with the 9015 part number markings is FIRST legal.
CraigHickman
Posts: n/a
It comes attached. Heat it up with a cheap gas station lighter, and pull it off with pliers. There's some adhesive in there that will liquefy with a little bit of heat.
Unread 18-01-2009, 22:47
Aren_Hill's Avatar
Build Nifty Things
there have been several tecniques of removing the gear on the FP(which does come attached to the black gearbox this year).
check this thread out
http://www.chiefdelphi.com/forums/sh...ight=FP+pinion
A guy who likes robots.
Unread 04-02-2009, 15:28
Johnny's Avatar
Johnny Johnny is offline
We do it for the pizza
FRC #1266 (The Devil Duckies)
Johnny has a spectacular aura aboutJohnny has a spectacular aura aboutJohnny has a spectacular aura about
I wouldn't recommend using heat or hitting the shaft of the fp motor whatsoever because they are easily destroyed. http://www.trossenrobotics.com/store...ar-Puller.aspx
These are the gear pullers we use for the fp/banebot motors. They are cheap and work very well.
Unread 04-02-2009, 15:37
Brandon Holley's Avatar
This same thread seems to come up this time every year....
If you do a quick search, you will see the one from last year...a lot of good ideas in there.
Heat does work, however its not necessary.
A nut splitter worked for us.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 04-02-2009, 15:43
Borisdamole Borisdamole is offline
mercernary machinist
AKA: Taylor
FRC #0973 (most with 973)
Borisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really niceBorisdamole is just really nice
Send a message via AIM to Borisdamole
careful not to get shavings into the motor if you use a dremel... that can seriously mess up your FP... If you do use a dremel, tape the opening on the motor shut so shavings cant get in....
OUTWORK US
fisher price gear railerobotics Motors 2 14-01-2009 17:20
fisher-price pinion gear bill mc gowan Motors 6 06-03-2006 11:14
Specs on the gear of the fisher price motor archiver 2000 0 23-06-2002 23:23
Fisher price motor gear specs archiver 2000 4 23-06-2002 23:23
FISHER PRICE GEAR BOXES archiver 1999 2 23-06-2002 22:07
