#10
Re: AM Planetary Gearbox (removing the fisher price gear/buying one without a gear)
Search this site for various ways to remove the pinion gear. You need to be very careful or you will trash the shaft and/or bearings.
We dremel a notch and then whack the pinion with a cold chisel. Cold chisel alone will work if you have a big enough hammer. I believe that Andy Mark was supposed to be a source for the motors this year, probably with the pinion attached. I also believe that the entire assembly (but not the motor alone) can be ordered as a fisher price replacement part. Beware - only the motor with the 9015 part number markings is FIRST legal. |
| fisher price gear | railerobotics | Motors | 2 | 14-01-2009 17:20 |
| fisher-price pinion gear | bill mc gowan | Motors | 6 | 06-03-2006 11:14 |
| Specs on the gear of the fisher price motor | archiver | 2000 | 0 | 23-06-2002 23:23 |
| Fisher price motor gear specs | archiver | 2000 | 4 | 23-06-2002 23:23 |
| FISHER PRICE GEAR BOXES | archiver | 1999 | 2 | 23-06-2002 22:07 |
