Go to Post What's a pirate's favorite robotics tournament? Aye-arrrrrrrrrr-aye, matey! - John Wanninger [more]
Unread 18-01-2009, 23:15
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Mounting Sprockets to the Rover Wheels
I like to use a 10-32 bolt that puts about 1 inch into the wheel. we run a tap in about .75 inch. The last .25 without threads makes it nice and tight.
I have just run them in without tapping but then they can't be disassembled without the threads getting screwed up.
2016 Central Illinois Winner. Curie Division finalist
Unread 18-01-2009, 23:23
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
We ended up just drilling out the holes in the AM wheels and putting 10-32 bolts through with aircraft nuts.
And yes, Loctite DOES melt certain thermoplastics! I'm not sure if the wheels are thermoplastic, but team 811 is not gonna risk it (again!)
Unread 19-01-2009, 05:04
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The wheel hubs are black polycarbonate.
Loctite dissolves polycarbonate.
Therefore, if you use Loctite to mount sprockets or hubs to the wheels, you will dissolve the plastic.
Use nylock nuts or split lock washers instead.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-01-2009, 08:03
Gdeaver Gdeaver is offline
FRC #1640
With the thickness of the spacer and sprocket, a 3/4" bolt would not penetrate very far into the hub. As many have pointed out it's best to either put a bolt all the way through and use nuts or use long enough bolts to almost go thru and tap them in. When the robots are on carpet and they take a side impact, the stress is distributed to all the wheels. With drifting this year the robot can hit the carpet with only 1 or 2 wheels taking the impact.
Beware of the carpet.
Unread 19-01-2009, 10:01
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
have you ever experienced this first-hand?
I would like to see some pictures,(besides this one, http://www.chiefdelphi.com/media/photos/17114)
nothing on the loctite website says it does(at least from what i can find)
http://www.loctiteproducts.com/
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 19-01-2009, 10:27
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Try looking here
___________________
- Tennyson, Ulysses
Unread 20-01-2009, 00:01
Kraftyman Kraftyman is offline
FRC #0847 (PHRED)
Kraftyman is an unknown quantity at this point
Greetings,
Please - so much strange information posted here. I am a plastics engineer and I have never heard of using Locktite on plastic - not because it will melt the polymer. Because locktite does not do much good with plastic. locktite is a chemical bond used with iron based metals. Other grades can be used to prep aluminum so that it can be bonded - but do not use with plastic as superglue would do just as well....... Good luck.
KraftyMan
newbie mentor for Nypro Oregon
Unread 20-01-2009, 00:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We tapped ours 10-32 with a cordless drill, and it works just fine. Not worried about cracking or stripping anything.
Press release: Nypro makes the rover wheels! Elgin Clock Kit & Additional Hardware 1 12-01-2009 12:01
Rover Wheels neoshaakti Kit & Additional Hardware 11 09-01-2009 14:34
Cost of Rover Wheels Boco Gear General Forum 3 08-01-2009 16:10
Mounting two output sprockets on andyMark :confused: EduardoVemny Motors 5 10-01-2008 21:37
mounting the wheels Stormhammer Technical Discussion 8 28-01-2005 14:41
