Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 18-01-2009, 21:49
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
pic: Nah, We just have a set for the Alpha bot and the beta Bot
Unread 18-01-2009, 21:50
Re: pic: Nah, We just have a set for the Alpha bot and the beta Bot
Might be a dumb question, but are you using 2 wheels per module? By the looks of the housing, the width seems to be quite large.
Unread 18-01-2009, 21:52
CraigHickman
Posts: n/a
It's actually another method of crab to do that. You can run the drive shaft straight down to the miter gears, which removes the need for either chain or spur gears to drive the wheels. It makes for a less complex swerve module, but at the expense of a hefty amount of (horizontal) space.
I'm guessing that's what they've got going here.
Unread 18-01-2009, 21:54
usbcd36's Avatar
usbcd36 usbcd36 is offline
AKA: "DOS"
FRC #2399 (The Fighting Unicorns)
usbcd36 is a jewel in the roughusbcd36 is a jewel in the roughusbcd36 is a jewel in the rough
Not to mention the fact that there are twice as many wheels as modules.
It might be a combination of the simpler swerve module idea and two wheels per module. The bevel gears could be between the two wheels in the module.
Unread 18-01-2009, 22:06
Spares buddy.
But Craig, wouldn't it be kinda sorta pointless to have more than 1 wheel per module? Don't you actually lose traction since its greater weight distribution? And of course, this is all assuming that they actually are using 2 wheels.
My Guess Based on the title of the pic: "Nah, We just have a set for the Alpha bot and the beta Bot"
2 Robots
Spare set of wheels for each bot or 2 wheeled modules for each bot
Should be fun either way
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I think theres two wheels per module with the drive shaft going down between the two. The second wheel on each module could be to spread the weight out so that the wheels wear slower...
-Dustin Benedict
Unread 18-01-2009, 23:39
Kevin Ray's Avatar
thefro526, you hit it on the head. We have two bots and two wheels on each module. We went with the two wheels only because the drive shaft leading down to the bevel gear comes down on the side of the wheel and creates unnecessary stress on the horizontal shaft. By sandwiching the bevel gear we equalize the downward force.
As for the traction, it's simple physics. We neither gain nor lose traction. We especially like that they swap out easily and will bring the 4 beta bot spares to the competitions--hopefully unnecessarily.
Unread 18-01-2009, 23:45
thefro526's Avatar
Mentor for Hire.
So awesome. I love when I'm right.
Thats an awesome way to build a crab though. I really like the amount of forethought that you've put into this. I wish you all the best! Whats the projected weight on the whole thing? It seems like it may get heavy pretty fast with the extra wheels though.
-Dustin Benedict
Unread 19-01-2009, 02:49
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Can you guys post a picture of a completed module when you have one done?
Unread 19-01-2009, 19:27
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Are you using custom hubs or AM ones on the wheels?
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 25-01-2009, 18:40
Kevin Ray's Avatar
To answer three of the above questions;
1. Yes, I'll post pics of the hubs completed and installed, I left the camera in the shop or I would have done it this evening.
2. The weight is heavy--about 4.7 lbs for the complete module. We were going to put some "speed" holes in it but just haven't gotten around to it yet. We will, however, if we're close on weight overall. We just installed them on the bot this week and used .078 thick thrust bearings in a delrin sandwich. OHHHH baby!
3. Yes, they are AM hubs, half are milled down to fit (We don't want to take advantage of our sponsors by having them make that which we can get elsewhere).
Introducing the FEDS 201 Bot for 2008! Tim Spry Robot Showcase 3 27-02-2008 19:03
pic: Q in arctic - nah just in indy - 1024's stompin ground Qbranch Extra Discussion 13 06-02-2007 17:29
pic: Team 176 bot just before shipping BobC Robot Showcase 2 28-02-2005 23:33
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
pic: Guess the Bot. CD47-Bot Robot Showcase 5 04-03-2004 14:35
