Go to Post Given the time Banebots has already cost us, what's a little snow? - pfreivald [more]
Unread 18-01-2009, 14:21
elbuo elbuo is offline
Teams #2884 and #1144
AKA: Yamil Asusta
FRC #1144 (Coquitron)
elbuo has a spectacular aura aboutelbuo has a spectacular aura aboutelbuo has a spectacular aura about
Camera Help
I've been trying to code the camera to identify 2 colors at once using the same code FIRST released for LV. But I can't seem to make it work
Looking for a guide on how to set it up I found this
http://forums.usfirst.org/showpost.p...64&postcount=1
And I was like :O But same thing happens and worst...It says I need NI Vision to make it work.
Can anyone help me out setting this one up?
Unread 18-01-2009, 15:00
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Camera Help
Hmm, we tried implementing that example yesterday and our robot behavior did not look like the video. I believe it is all a matter of tweaking the PID controls, but then you have to have a good understanding of PID controls to know how to tweak that.
There is a white paper on PID controls here http://www.chiefdelphi.com/media/papers/1823 that may help you understand how to tune the PID.
Good luck, I hope this information helps you
Unread 18-01-2009, 15:09
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: Camera Help
I'll assume you have checked the inverted buttons and pwm inputs to make sure they match with your config?...
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 18-01-2009, 15:40
AKA: Yamil Asusta
Re: Camera Help
No man I admit I'm uber lost and I have no hel from my team side -.-
The link for the PID doesn't work. It says something about some coffee shop trial...:S Can someone re-upload it?
Unread 18-01-2009, 17:09
Re: Camera Help
If your haven't activated NI Vision, you should enter in the same serial number as you typed in for LV I believe. It will be necessary to activate it or get the 30 day eval before the LV code will work.
Greg McKaskle
Unread 18-01-2009, 23:47
AKA: Yamil Asusta
Re: Camera Help
Well the serial didn't work
That is very very weird. I'll try using my personal laptop.
BTW, what is needed to test this? Besides the camera and the full system running...
Unread 19-01-2009, 08:09
Re: Camera Help
At this point, I'd encourage you to call the NI number for support to make sure your activation works. The next step I do is to run a LV example such as My Progs/National Instruments/LabVIEW 8.5/examples/FRC/vision/single color...
This lets you see what the camera sees and lets you play with colors and lighting most easily. After that you can try other examples such as the two color gimbal.
The setup for these examples is pretty standard for everything else on the control system. DS, computer, cRIO, and camera all connected with enet. Orange cable between camera and cRIO. Be sure to enable the DS -- doesn't actually matter for camera demos, but a good habit to get into.
Greg McKaskle
Unread 19-01-2009, 11:01
AKA: Yamil Asusta
Re: Camera Help
Something weird is that I just opened both of the examples in my pc
I'll see tomorrow what seems to be the problem.
I'll see if it works Thanks a lot man! I'll report my progress tomorrow
Camera Help Team1710 Technical Discussion 2 08-01-2009 22:10
Camera HELP! yarb65 Programming 5 29-01-2007 21:58
Camera Help itzrobz Programming 15 24-01-2007 17:18
Camera Help (New to Camera Programming) Idaman323 Programming 6 14-01-2006 03:56
camera help! |20807 61|2|_ Programming 5 08-01-2006 14:44
