Go to Post Gerardo?!!?! Auugghh! Dave says "that's NOT pimp!!" - dlavery [more]
Unread 18-01-2009, 23:03
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
How fast can you type?
I can type 39 wpm with a 94% accuracy according to the following test.
3 minutes Wizard of Oz http://www.typingtest.com/default.asp
Take this test and see how fast you are. Use the same settings for uniformity and post your results here.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 18-01-2009, 23:08
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: How fast can you type?
I used to be able to type 75 wpm on a standard manual typewriter, with only 2 mistakes during (I think) a 2 minute test. Back then we had to erase our mistakes, line up the paper again, and retype the letter. Computers used punch cards, so if you made a mistake programming, it usually meant punching a replacement card.
I don't run java on my computer, so I can't take the test you linked too....but I could get out one of the old typewriters and see how sorry I am now that I have a backspace key
Unread 18-01-2009, 23:18
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
68 wpm at 94% accuracy.
Know I've done a bit better on a similar test though.
Unread 18-01-2009, 23:30
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
70 WPM 97%
Once upon a time long long I was able to hit 100
Unread 18-01-2009, 23:41
MrForbes's Avatar
AKA: Jim
I used this one
http://www.typeonline.co.uk/typingspeed.php
and got 73 and 80 wpm with 4 mistakes each time.
edit: I'm using an IBM keyboard made in 1992
Unread 18-01-2009, 23:46
Herodotus's Avatar
Herodotus Herodotus is offline
Mountain Dew Bandolier Man
AKA: David Resowski
FRC #0910 (Foley Freeze)
Herodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond reputeHerodotus has a reputation beyond repute
Highest I recall ever getting was something like 120 - 130 wpm, albeit with liberal use of the backspace key. I took the Oz test you linked to and managed 50 wpm with 96% accuracy. To be fair, I am typing on my Dell mini 9, an 8.9 inch netbook.
I am always doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
--My Life in FIRST--
2009 Detroit Xerox Creativity Award
2009 Detroit District Finalists - Thanks to 1856 and 2620
2009 Kettering District Quarter-Finalists - Thanks to 1504 and 1025.
2008 Kettering Kickoff Champions - Thanks to 67, 1075 & 2619
2008 MARC Finalists - thanks 67 & 226
2008 Great Lakes Finalists - thanks 66 & 217
2008 Western Michigan Semi-Finalists - thanks 2337 and 1504
2008 GLR Judges Award Winner
2007 Curie Division Champions - thanks 330 and 1270
2007 ARC Champions (13 and 0, plus scoring a double-keeper!) - thanks 1625 and 313
2007 MARC Champions - thanks 1732 and 1023
2007 Xerox Creativity Award - Western Michign
2006 I.R.I. Champions - thanks 71 and 1625
Unread 19-01-2009, 01:00
mbeardsworth mbeardsworth is offline
Lord of the Subversion Repository
AKA: Michael Beardsworth
FRC #2521 (South Eugene High School Robotics)
mbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of lightmbeardsworth is a glorious beacon of light
89 WPM, 95% accuracy... could be better...
Unread 19-01-2009, 01:10
shimniok shimniok is offline
FRC #0443 (Freelance Robotics)
shimniok is an unknown quantity at this point
Send a message via Yahoo to shimniok
Wiz:
Try #2 84 wpm net; 87 wpm 95% accuracy
Try #3 95 wpm net; 102 wpm 93% accuracy
Could probably do better if not sitting here on the sofa with the laptop.
FRC Team 443 - Freelance Robotics, Club Workshop
Unread 19-01-2009, 07:58
ComradeNikolai ComradeNikolai is offline
AKA: Nicholas
FRC #2603 (Team Hornet)
ComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to beholdComradeNikolai is a splendid one to behold
Originally Posted by squirrel View Post
I used the same one; 92 words per minute with no mistakes. I enjoy the ability to use my backspace key.
Now I just have to increase that to my maximum rate of speech... (250-300 wpm, thank you debate)
I cut myself shaving with Occam's razor.
Unread 20-01-2009, 18:46
Kricu's Avatar
Kricu Kricu is offline
AKA: Nick
FRC #2053 (TigerTronics)
Team Role: Human Player
Kricu is an unknown quantity at this point
Send a message via AIM to Kricu
Ehh I only typed at 45 wpm with 95% accuracy. Of course if I didn't have to type what they wanted me to then I would be able to type much faster. Like essays and things that are in my own words I can type much faster.
Unread 20-01-2009, 18:54
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
On that test, 67 wpm, 97% accuracy.
It depends what I'm doing though- I can tell I'm typing much faster right now because I don't have to look at the screen to read exactly what I have to type as I'm typing it, I can just put down whatever it is that I want to say. Similarly, I type much more slowly when I'm retyping information, such as off of a paper, or the passage on the typing test. I also type more slowly on unfamiliar keyboards, as my fingers end up hitting the wrong keys much more frequently. (:
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 20-01-2009, 19:34
Kristian Calhoun's Avatar
Kristian Calhoun Kristian Calhoun is offline
Celebrating 20 years of 25
FRC #0025 (Raider Robotix)
Kristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond reputeKristian Calhoun has a reputation beyond repute
Send a message via AIM to Kristian Calhoun
On The Wizard of Oz test, I managed 102 wpm @ 94% accuracy.
Raider Robotix: Home | Twitter | Facebook | Instagram
Brunswick Eruption: Home | Twitter | Facebook
Unread 01-02-2009, 01:39
Darkcrosbone Darkcrosbone is offline
Master of....nothing actually...
FRC #0956
Darkcrosbone will become famous soon enough
Net Speed: 52 WPM
(words/minute)
Accuracy: 83%
Gross Speed: 63 WPM
(words/minute)
Unread 01-02-2009, 07:21
Michelle Celio's Avatar
Michelle Celio Michelle Celio is offline
dream. belive. accomplish.
Michelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond reputeMichelle Celio has a reputation beyond repute
118 wpm with 92% accuracy. It's a slow day.
(I've always been known for quick typing, and speed talking.)
UCF History & Education '12
Sometimes you just need to step away
"They were shown as everything is shown, for, like the lens of a camera, history is a force that does not discriminate."
JRW <3
Volunteering: IRI - Reset 07/08, Mission Mayhem 07 - Referee
TnT - Referee 07/08, FLL Florida State Tournament - Judge 08/09
Florida Regional 08 - Reset/Repair, Florida Regional 09/10 - Photographer
8 Events - Web Evaluator 08/09/10
Unread 05-02-2009, 21:58
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
71 wpm, 86 percent accuracy... but hey, that's wat spell check is for... right?
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
How fast have you broken stuff? hihihiflcl81pig General Forum 16 25-01-2009 18:13
How fast can your robot shoot? Joe_Widen General Forum 23 27-02-2006 07:32
How fast can the corner goals detect balls going in? Excelsior Technical Discussion 3 22-01-2006 01:24
how fast are you sburro General Forum 29 10-05-2004 17:25
How fast are you planning to push/pull a goal? Anton Abaya Rules/Strategy 7 12-01-2002 23:33
