Go to Post A charged battery beats a dead battery any day. - Al Skierkiewicz [more]
Unread 19-01-2009, 02:01
Blair Frank's Avatar
Blair Frank Blair Frank is offline
Writer and Alumnus
FRC #0852 (Athenian Robotics Collective)
Blair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the roughBlair Frank is a jewel in the rough
Re: cRIO has no code
We've found that the DS needs to be set to "disabled" in order for the code update to take, and that usually works.
Best of Luck!
-Blair
Proud alumnus of Team 852, the Athenian Robotics Collective.
Pneumatics in a nutshell: Put together an elaborate series of pipes, canisters, cylinders, valves and hoses; then fill that system with highly pressurized air, and hope that it doesn't blow up in your face.
"Battery: No Code" after uploading .out file to cRIO knine143 FRC Control System 1 20-12-2008 22:14
cRIO - motor controller code (esp. victor) ericand Programming 8 06-12-2008 22:09
Team 166 Has Open Sourced Its Code platypus Programming 13 09-02-2008 16:03
Does anyone has code for accelerometer? sjung9442 Programming 2 30-01-2006 21:37
Has anyone craked the code yet Jeremy General Forum 2 09-01-2004 14:12
