Go to Post Last year we saved a ton of money by using a good bit of square tubing for the frame of our robot, square tubing is a lot cheaper then C channel. We get to use so much raw material that the cost should go down in certain places. - Derrick Maust [more]
Unread 19-01-2009, 02:49
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: pic: Nah, We just have a set for the Alpha bot and the beta Bot
Can you guys post a picture of a completed module when you have one done?
Unread 19-01-2009, 19:27
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
Are you using custom hubs or AM ones on the wheels?
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 25-01-2009, 18:40
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
To answer three of the above questions;
1. Yes, I'll post pics of the hubs completed and installed, I left the camera in the shop or I would have done it this evening.
2. The weight is heavy--about 4.7 lbs for the complete module. We were going to put some "speed" holes in it but just haven't gotten around to it yet. We will, however, if we're close on weight overall. We just installed them on the bot this week and used .078 thick thrust bearings in a delrin sandwich. OHHHH baby!
3. Yes, they are AM hubs, half are milled down to fit (We don't want to take advantage of our sponsors by having them make that which we can get elsewhere).
Introducing the FEDS 201 Bot for 2008! Tim Spry Robot Showcase 3 27-02-2008 19:03
pic: Q in arctic - nah just in indy - 1024's stompin ground Qbranch Extra Discussion 13 06-02-2007 17:29
pic: Team 176 bot just before shipping BobC Robot Showcase 2 28-02-2005 23:33
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
pic: Guess the Bot. CD47-Bot Robot Showcase 5 04-03-2004 14:35
