Go to Post Like my programming class teacher has said multiple times: "Stop complaining on reddit about your code not compiling and actually fix it". - [more]
Unread 18-01-2009, 19:04
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Threading
While I am familiar with threading and have used it many times I have never done so in C++. Can anyone refer me to a good threading tutorial?
Unread 18-01-2009, 19:10
Jared Russell's Avatar
Taking a year (mostly) off
Re: Threading
For what environment? Threads are a system-dependent feature and can be implemented at various levels of the system.
POSIX is a pretty commonly used threading library on Linux-based systems; you basically call a "create thread" function and pass it a function pointer for whatever code it is that you want to run asynchronously. Primitives like mutexes and semaphores are included.
This is a good overview of POSIX threading.
Unread 18-01-2009, 19:38
nickmagus's Avatar
AKA: Nick Clayton
Re: Threading
for the cRio.
Unread 18-01-2009, 19:39
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Re: Threading
Here is another old thread dedicated to it. http://www.chiefdelphi.com/forums/sh...ad.php?t=71138
On the CRIO, they are called tasks. I am not sure how to use them yet myself. That part of the WPI manual is blanked out. Look at the tasks.h file in the WPILib folder. It helps a little. Also look at the camera examples in WindRiver. I believe they are using seperate tasks for image aquisition.
hope this helps a little
Unread 19-01-2009, 00:32
nickmagus's Avatar
AKA: Nick Clayton
Re: Threading
Does anybody have any sample code of a thread (task) that they have got working. At the moment it appears that the task is being deleted.
Unread 19-01-2009, 08:15
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Re: Threading
Hi nickmagus,
I'd recommend you use the WPILib Task class, which is a simple wrapper over the VxWorks task/thread API. Here's some sample code to get you started:
To define a task, you have to give it a name. The task will show up in debugging as FRC_task_name, where task_name is the value passed to the Task constructor. The second argument to the constructor is a FUNCPTR, which is your threading function.
MyRobot::RobotInit()
    Task myTask("image_process", imageProcessThread);
    myTask.Start();
The thread function must return an int and take a variable number of arguments (up to 10), which is denoted in C/C++ by "..." as the last function argument.
Your task will run from start to finish once, after Start is called. If you don't want it to be deleted, then put a loop in it so it doesn't return until you're done:
int imageProcessThread(...)
   va_arg argptr;
   // do stuff...
To get access to any of your 10 arguments, you must use the va_arg macros, which are explained here:
http://www.cppreference.com/wiki/c/other/va_arg
If you are using shared data between threads, you must be sure to enforce synchronization between the threads. WPILib has an interesting abstraction for synchronization with semaphores - examples are in the C++ Programming Guide - but it's really more confusing in my opinion. PM me if you need help with synchronization.
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 19-01-2009, 14:18
nickmagus's Avatar
AKA: Nick Clayton
Re: Threading
Thanks for your help Shinigami. Here's what I have found. If you start a task in an init function it is deleted when the init function ends. It appears the task thinks its a local object but when I try to put the definition as a global I get an error "error: expected `,' or `...' before string constant". Does anybody know how to make it global (I will experiment and post the answer if I figure it out.)
Unread 01-02-2009, 15:47
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Re: Threading
I'm having difficulty getting the small code sample to compile, Shinigami. Hopefully, you or someone else could lend a hand?
Here is what I currently have:
#include "WPILib.h"
/** TODO: Change this message.
 * This is a demo program showing the use of the RobotBase class.
 * The SimpleRobot class is the base of a robot application that will automatically call your
 * Autonomous and OperatorControl methods at the right time as controlled by the switches on
 * the driver station or the field controls.
class Robot : public SimpleRobot
	RobotDrive myRobot; 	// robot drive system
	Task CameraThread;
public:
	Robot(void):		// these must be initialized in the same order
		myRobot(1, 2),	// as they are declared above.
		CameraThread("camera_thread", imageProcessThread())
		GetWatchdog().SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop
	void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 					// for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	void OperatorControl(void)
		GetWatchdog().SetEnabled(true);
		while (IsOperatorControl())
			GetWatchdog().Feed();	//woof.
	   // do stuff...
		return 1;
START_ROBOT_CLASS(SimpleRobot);
Thanks.
Unread 01-02-2009, 17:58
AKA: Harry Bock
FRC #1350 (Rambots)
Re: Threading
Chief Pride,
I can see two small problems with your code, both of which are very easy to fix. The first:
Originally Posted by Chief Pride View Post
When you pass a function as an argument, you don't use parenthesis after the thread - parenthesis indicate a function call, not the function itself. So it should be just
CameraThread("camera_thread", imageProcessThread)
Secondly, your task function (imageProcessThread) must be declared outside any class definition. So move it after the class ends and before START_ROBOT_CLASS.
You may also have to put a "prototype" of your function before your class definition to make the compiler happy, like so:
int imageProcessThread(...); /* prototype */
class Robot : public SimpleRobot {
   return 1;
Good luck and let me know if you have any more trouble.
Unread 01-02-2009, 21:32
<3
AKA: James Kiefer
Re: Threading
Thank you very much, Shinigami.
Although, if you have a minute, would you mind letting me know why the prototype makes the compiler happy?
Thanks.
Unread 02-02-2009, 18:04
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Re: Threading
The compiler compiles the source code from top to bottom, so if you have a source file like :
test_function();
void test_function(void)
{ //do stuff
it is best to prototype "test_function" before you call it. This lets the compiler know that there is a definition of the function. Some compilers might not compile the source code without the prototypes, others might throw a "implicit reference" warning.
Unread 02-02-2009, 19:23
Re: Threading
There is a good example of how to utilize tasks in WPILib source. Check out StartCameraTask in the AxisCam.cpp file.
Unread 05-02-2009, 14:41
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Threading
here is a brief overview:
#include...
Task tsk("myTask",MyTask);//creates task "tsk" identified by the name "myTask" on the cRIO, calling function MyTask
//put variables to be accesed by the task and norm. code here
RobotDrive myRobot(1,2);
class ...
void Auto()
    while (!tsk.IsReady())
    tsk.Start(1);//start MyFunction on another thread w/ args (1);
    while (IsAuto())
    tsk.Stop();
};//end of class
void MyFunction (int arg1)
//code using arg1
You can have up to 10 int args, and the function must be global
Watchdog.Kill();
Threading on the CRIO dpeterson3 Programming 4 04-01-2009 17:56
Threading tool not working.... strange? q_prof Inventor 3 20-02-2006 00:14
Muti-threading Ryan M. Programming 19 26-04-2004 09:10
