Go to Post Gotta love the blurred robots :cool: - Steven Donow [more]
Unread 19-01-2009, 09:28
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Thumbs up [FTC]: Field Management Software Review
We tried out the FMS this weelend to test our code and run matches.
It was VERY COOL. I can't imagine why anyone thought this program would be too complicated for teams to use. (Let's face it, if we figured out how to build and program our robots, this was a snap
Connecting to the NXT with USB to read the team name and then initiate the Bluetooth worked much better than most of the other Bluetooth connection methods we've been using. We had our team practice the full pre-match hookup and setup.
It's fun having a second monitor hooked up to the laptop to display the MatchTimer on a screen all by itself.
We just had two controllers and one robot so the matches were very one-sided
As for the question of whether the "End Match" or "End Of Autonomous" would halt the robot in the middle of a long movements... the results were very good.
I was surprized that most times the robot would correctly stop in the middle of a motion. We did have the occasional instance where the robot acted oddly while is was sitting there (shimmying back and forward), but that may have been a "regular" motor glitch
I guess the real answer here is that at the end of auto, the program is halted and the teleop program is started immediately in "Disable" mode. So the first commands issued in Teleop have the effect of resetting the motor controller back to idle.
This is the magic sequence that I wanted to discover to ensure that our robot would be code-legal. I'm confident now that we'll get through inspections... Phew...
*Thanks* FIRST, for making the FMS public so we can get through this transition.
Note: After having to manually reset for NXT for auto several times, I do wonder why the FMS isn't able to automatically start the bot in Auto AND teleop. I know the Chooser Program is used to put the name of the Teleop program in a text file so the FMS can know it... I wonder why BOTH program names arent done this way... then the match start could be fully hands-free Next year maybe ...
Phil Malone
http://www.GEARSinc.org
[FTC]: Field Management System KayyPii FIRST Tech Challenge 9 19-02-2009 10:26
Field Management System fritzdejongh FRC Control System 2 08-01-2009 18:41
[FTC]: Field Drawings? Madison FIRST Tech Challenge 1 14-09-2008 15:16
[FTC]: FTC Software Requirements Al Skierkiewicz FIRST Tech Challenge 17 18-12-2007 11:55
