Go to Post when you think you are here to compete against other teams, thats when bad things start happening... - KenWittlief [more]
Unread 19-01-2009, 10:20
nadavsen2 nadavsen2 is offline
FRC #2231
nadavsen2 is an unknown quantity at this point
Two color tracking problem
i'v trying to compile the Two Color Tracking to the CRio. But when
im turning on the CRio it shows me "Battary : No Code ".
Can anyone help me solve this problem?
thanks a lot
Unread 19-01-2009, 10:59
Mikesername's Avatar
Mikesername Mikesername is offline
meh.
AKA: Mike Dame
FRC #3044 (Team 0xBE4)
Mikesername is an unknown quantity at this point
Send a message via AIM to Mikesername
Re: Two color tracking problem
Could your battery be dead?
[ ballston spa robotics | www.team3044.com | team BE4]
Unread 19-01-2009, 11:14
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
Did you download the code into the cRio yet? Under the 'FIRST' menu item, select 'download'. This must be set up initially under 'Window->Preferences', then under 'FIRST Downloader Preferences. Here you need to set your team number and the location of your .out file. This will be found in your workspace, under a directory called ppc(something or other). Keep drilling down until you find the file with a .out extension. Once it is downloaded successfully (no errors reported by WorkBench), then cycle power on the cRio. Now check the Battery indicator.
Steve
Unread 19-01-2009, 14:44
FRC #2231
Thanks , its working now.
Two Color Tracking Demo Bharat Nain Programming 43 25-01-2009 18:58
Team 399 Color Tracking EricGoodchild Robot Showcase 2 15-01-2009 22:38
Tracking two lights Render Programming 5 29-01-2007 18:14
Tracking Color? haywirerobotics Programming 0 14-01-2006 13:55
tracking two tetras? Anton Programming 5 09-02-2005 15:02
