Go to Post I also like how the FTC folks are able to get involved with the FRC process this year, but it's always a bit of a let down when you're told you can't launch things into the air. - s_forbes [more]
Unread 17-01-2009, 16:02
Brian1885 Brian1885 is offline
FRC #1885
Brian1885 is an unknown quantity at this point
SMC Solenoid Order
I have been trying to order Festo solenoid, but found that it was not standard Festo product and is hard to get. So, we have decided to use smc solenoid. However, the SMC does not provide online order service..
Is there place I can order SMC solenoids? or Do I have to contact the distributor and would the distributor have the part we need?
Unread 17-01-2009, 16:32
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: SMC Solenoid Order
Googling turned up this -
http://www.coastpneumatics.net/?gcli...FQrAGgodLyYvnw
For the 2008 SMC parts, including pics and part numbers, go here:
http://usfirst.org/uploadedFiles/Community/FRC/FRC_Documents_and_Updates/2008_Assets/Manual/2008%20KoP%20Checklist-RevB.pdf
Edit - it looks like the standard double solenoid valve SMC donated to teams for years is out of stock. I sent an email to customer service on that site asking them about lead time and availability. I will post here if I receive a response.
Unread 17-01-2009, 17:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You might try Motion Industries or Applied Industrial.
Unread 19-01-2009, 08:51
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
You are correct, both have a similar industrial strength valve for what we need.
If only they didn't cost $176.64 We'll call SMC.
GitHub
Unread 19-01-2009, 11:46
novamx3 novamx3 is offline
FRC #2502
novamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to beholdnovamx3 is a splendid one to behold
I work for a pneumatic distributor that reps a line that is directly interchangeable with the SMC line. It is a Korean manufacture called TPC pneumatics.
If you can give me the SMC part numbers you are looking for I can get you the TPC direct interchanges.
For example:
SMC #
SY3140-5H
TPC #
DV1140-5H Single Solenoid 24VDC 10MM valve
$39.60 each
SMC parts - How do I order? rcflyer620 Kit & Additional Hardware 2 26-01-2008 21:26
SMC single acting solenoid Sam2197 Pneumatics 1 24-01-2008 00:18
SMC Solenoid Vendor? sircedric4 Pneumatics 1 17-01-2008 11:30
SMC product order form $aravind.k$ Pneumatics 2 17-02-2004 14:24
Single Solenoid Valve SMC Chubtoad Technical Discussion 3 20-01-2002 15:16
