Go to Post All this community stuff is actually pretty fun! :) - JBotAlan [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 19-01-2009, 13:05
Kory's Avatar
Kory Kory is offline
Kory
FRC #1569 (Haywire)
Kory is an unknown quantity at this point
Re: Connecting Axis camera to cRIO
I am having the same issue as Jill. The camera works when connected to everything but port 2 on the cRIO. Our team captain talked to a network guru who told him that it will not work because of a subnet error. All the devices besides port 2 on the cRIO have an IP of 10.xx.yy.zz (xxyy is based on the team number, zz is decided by what device it is) Port 2 on the cRIO however, is 192.168.0.3. I'm not sure if this is correct but he said when a subnet mask is set to 255.255.255.0 it means ignore the first three sets on numbers because they are the same. However the first three numbers of port 2 on the cRIO are not the same. I believe this is what's causing the problem. Is there a way to change the IP adress on port 2 of the cRIO. The documentation says there is but doesn't specify exactly how. Do any of you have it working with 192.168.0.3? Did you configure it that way or is that the default? I am out of ideas.
To everything a season a time, to every purpose under heaven.
Axis camera without the cRIO CrazyCarl461 NI LabVIEW 12 17-01-2009 10:53
Connecting Power Distribution block to cRio Paul Rodi Electrical 2 05-01-2009 18:20
AXIS Camera nickmagus Programming 1 03-01-2009 20:06
Program Axis Camera in c++ excel2474 Programming 5 22-12-2008 17:14
axis camera - problem s0crates FRC Control System 11 16-12-2008 09:34
