Go to Post To put it simply, its clearly become this. The teams that can score a lot, do well. Rather shocking, isn't it? It doesn't matter if you're a shooter, dumper, power dumper, gravity dumper, spitter, flinger, dunker, shumper, barfer, dropper, or whatchamacallit. Points are points. - Looking Forward [more]
Unread 19-01-2009, 13:40
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Cabling the Camera
Make a loop of the wires about 4" in diameter just below the camera, this will allow for movement.
Tell the difference: 2007 CMU Camera, 2006, 2005 camera? Chris_Elston Programming 2 07-01-2008 13:11
Where do I begin to get the robot to move using the camera? Ianuser Programming 10 16-02-2007 17:55
How is everyone setting the angle for the shooter/camera? waialua359 Programming 6 26-01-2006 21:51
jumper cabling from sensors to controller Gary Dillard Electrical 4 23-12-2005 07:42
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
