Go to Post I must caution against using my sense of humor as any sort of litmus test for good taste. - dlavery [more]
Unread 19-01-2009, 14:31
markulrich's Avatar
markulrich markulrich is offline
Head Captain and LabVIEW Programmer
FRC #2129 (Ultraviolet)
markulrich has a spectacular aura aboutmarkulrich has a spectacular aura about
Can we cut holes in the bumper plywood for the bolt heads?
My team assembled the 2009 Drive Base as instructed in the C-Base-User-Guide. The heads of the bolts used as axles stick out of the sides, so we were planning on cutting holes in the bumper plywood where the bolts are and mounting the bumpers against the C-channel.
I'm sure that this isn't the purpose of R08(L)
The BUMPERS must be fixed to the BUMPER PERIMETER.
but technically it seems that if a string was wrapped around at the height of the bolt heads then we would need to have a space the width of 1 bolt head between the C-channel and plywood, which would be unnecessarily complex and not (I think) the intention of R08. What do you think? Have I misread the rule? Is this a question for the GDC?
Thanks!
Can the robot extend outside of the bumper zone. markulrich Rules/Strategy 15 08-01-2009 08:21
Building the kitbot frame- mate the holes? Bryan Herbst SolidWorks 6 11-05-2008 13:44
Making your own plywood for the bumpers BeyondRamo General Forum 4 28-02-2008 20:02
can we cut holes in bumpers????????????? robouser72 General Forum 3 04-02-2008 18:38
How to cut flat sided holes for Globe and Door motor Max Lobovsky Motors 8 13-01-2005 14:09
