Go to Post the whole process is the most valuable part, not the award itself - Rich Kressly [more]
Unread 18-01-2009, 18:13
AKA: Dr. Brooks
no team (WRRF)
db25 ribbon extender
We would like to find short (6 inches or so) db25 ribbon extenders
so that we can move the breakout boards for the solenoid and
analog inputs down into spare space in the cRIO where they would
be out of harms way. We have found such on the Digikey web site,
but they do not have stock on any of them. Has anyone found these
anywhere? We would like to avoid making them.
Eugene
Unread 18-01-2009, 21:12
Re: db25 ribbon extender
Don't be afraid of making them. Putting insulation-displacement connectors ("IDCs") on ribbon cable is fun.
Unread 19-01-2009, 07:51
AS Alan has pointed out, it is easy to make the appropriate jumpers. Digikey also sells both ribbon cable and the connectors. Be sure to order the right sex and connectors with the right number of pins. The NI modules are 37 pin and you must wire all pins. (Pin 37 is an enable pin I believe.) You can purchase the crimp tool to assemble the connectors or you can use a small vise. Please be sure that everything is insulated when you move the interface boards. And while we are on the subject, the jumper to monitor battery voltage at the OI must be in place on the first analog module. This is required by robot rules per R64.
<R64> A National Instruments 9201 module must be installed in slot 1 of the cRIO Mobile Device Controller. An analog breakout must be connected to this module. A jumper must be installed on the “Battery Voltage” and “Power” pins on the analog breakout.
Unread 19-01-2009, 07:58
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Just for clarification I'd post the question on the official FIRST GDC FRC forum and ask if it is okay to replace the cables with ribbon cables.
For years we used ribbon cables from the IFI radio to the RCs. There is nothing technically wrong with that since it is 422, but some inspectors were uncomfortable with that and eventually last year the question was asked of the GDC and they ruled it must be the cables shipped in the KOP.
I didn't agree with their ruling but it is what it is and that was the rule.
So to make your life more comfortable in inspection, I'd ask the question of the GDC, and if positive, your students can take a printout with them to inspection.
Ed Barker
Unread 19-01-2009, 08:06
Ed,
This question was answered in the Q&A last week and is allowed this year. Check "Ribbon cable for Digital I/O module" under the control system sub forum in the robot forum of the Q&A.
Unread 19-01-2009, 11:09
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
For more clarity, the Digital Sidecar uses a 37-pin cable but the Analog and Solenoid Breakouts use 25-pin cables. If memory serves, that same Q&A response also allows moving the Breakouts via ribbon cables.
Be careful if you want to move the Solenoid Breakout with a 25-pin cable - the NI 9472 is capable of driving 750mA per output but an attached ribbon cable may not be so capable.
Russ
Unread 19-01-2009, 14:35
.:Brianna:.'s Avatar
.:Brianna:. .:Brianna:. is offline
President/Coach/Scout
FRC #0433 (Firebirds)
.:Brianna:. has a spectacular aura about.:Brianna:. has a spectacular aura about.:Brianna:. has a spectacular aura about
which ribbon cables do you suggest replacing the gray cables that connect the cRIO to the digital side car with? a supplier and part number would be wonderful.
2007 Motorola Quality Award
2008 Philadelphia Engineering Inspiration Award
2009 Philadelphia Chairman's Award
2009 Connecticut Engineering Inspiration Award
2010 Pittsburgh Chairman's Award
2010 Pittsburgh Entrepreneurial Award
Hot like fire
Fly like birds
Unread 19-01-2009, 23:27
AKA: Dr. Brooks
no team (WRRF)
For cable, see page 46 of the online Digikey catalog
searching for MB37R-5-ND will get you there
For plugs and receptacles you can search under
HMM37H-ND for the plug
HFM37H-ND for the receptacle
and land on page 48
There are 25 pin cables, plugs and receptacles as well.
There is some shielded cable on the bottom right hand
side of page 46 as well.
As noted earlier, the current limit for the 28 gauge wire
used in this ribbon cable is listed at .228 amps and the
solenoid outputs can exceed this.
There are always the screw machine db-xx connectors
that one can resort to. We get ours from www.steinair.com.
These can handle up to 20 gauge wire and will be very reliable,
but it will be tedious to be crimping and inserting them one by one.
Unread 19-01-2009, 23:29
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
We've been doing a bit of searching for this also, thank you!
Radio Boost/Range Extender? nickbotix Electrical 16 21-04-2008 21:24
Ribbon cable Pneumaticsman Electrical 4 08-02-2008 20:00
CIM motor shaft extender (adapter) Arkorobotics Motors 9 08-02-2006 06:53
Ribbon Cable emusteve Electrical 6 13-01-2006 16:33
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
