Go to Post I have gone and confused myself again. Why does this happen every time? - Jay Trzaskos [more]
Unread 19-01-2009, 14:29
CDH Jeff's Avatar
CDH Jeff CDH Jeff is offline
FRC #2450 (Raiderbots)
Team Role: Electrical
CDH Jeff is an unknown quantity at this point
Ground Clearance
Is there a specific height off the ground that parts of the robot have to be, other than the wheels? Or can something like, say, a ramp touch the floor?
"why are 'standard' and 'metric' different?! metric should be the standard!"
Unread 19-01-2009, 14:55
Re: Ground Clearance
The rulings on Q&A seem to indicate that the only reason something can touch the floor is for feedback, and even then, it's limited. If you put a ramp on the floor, you'll be called on <R06>.
As for specific heights, the bumpers have to be in the bumper zone (Section 8.2) and the trailer hitch has to be at a certain height.
Unread 19-01-2009, 15:03
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
My week-old QA interpretation was that anything you want can touch the floor, so long as it does not provide sufficient drag or thrust to affect the low-friction dynamic. If you coated the floor-contacting portion of your ramp with rover-wheel material, then it would certainly not provide any traction or braking beyond what you could expect with the wheels.
edit: I can't find the QA response that I had justified that in my mind with, ignore me until I find it.
edit2: Here's the QA response, which gives a pretty broad ruling:
1. Other parts of the Robot may contact the floor, as long as the part does not provide any traction for the Robot.
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
There is no specific height that the robot must be (other than Erics points). Anything touching the floor that could be considered a traction device (even if it produces very little to no traction) will be cause for the inspectors to look closer and possibly fail your robot at inspection.
Between the regolith sheets (at the Kickoff in Manchester) there were small ridges. I'd suggest at least an 1/8" clearence for any non wheel part.
___________________
- Tennyson, Ulysses
Unread 19-01-2009, 15:14
You might read the most recent batch.
For example, there's this one, which pretty much bans slick balancing items, even if they won't affect the CoF.
There's also this one, which effectively rules that you MUST use the Rover Wheels for traction--having the same material on something else is illegal if it's used for traction.
They've tightened up a little bit. It's not going to affect many designs, I don't think, but it's enough to affect your interpretation a bit.
Unread 21-01-2009, 14:58
Jeff,
There are a few rules that come into play here, but the test will be if the device contacting the floor provides traction or braking (more than 5% in any direction) in addition to the wheels provided and that said device does not damage the playing field surface. That second one is far easier to determine. I am guessing you think that that a ball chute that follows the floor is needed to pick up balls. If you were to investigate a little further, I think you would find that the ball diameter is sufficient to allow pickup without touching the floor.
pic: Virginia's rear ground clearance falconmaster Extra Discussion 7 25-01-2008 23:31
Think about Robot Ground Clearance ggoldman General Forum 12 10-01-2007 08:22
Chassis Clearance T3_1565 Technical Discussion 7 08-01-2007 18:02
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
pic: Ground Clearance (or the lack thereof) ahmed Robot Showcase 14 15-02-2005 17:02
