Go to Post your time is better spent in the stands, watching what the robots actually do, as opposed to listening to the builders talk about what they're [I]supposed[/I] to do. - sanddrag [more]
Unread 19-01-2009, 15:48
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: Driver Station 0.1" 3x20 Header Cable?
Originally Posted by Travis Hoffman View Post
Has anyone located a source for a receptacle and cable (multicolor ribbon, preferably) that mates to the 3 high x 20 wide bank of 0.1" I/O header pins on the Driver Station? I'd like to run a single cable connection to a custom button box and pick and choose which I/O I wish to use from inside the box.
I agree with your strategy, but I couldn't find such a cable.
During beta testing I made up a PCB that had header sockets that mated with the Driver Station and then had a 24pin ribbon cable connector.
You only need to connect to a few of the power/ground pins, so I used a 2x20 and a 4x1 connector. I wrote up a paper on getting it built. At the time I did the PCB I didn't know there were no internal pullups (D'OH)
This is the sort of thuing that takes a day to design and $60 and 3 days to get built from ExpressPCB.com.
Phil Malone
http://www.GEARSinc.org
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Driver Station Update ExarKun666 FRC Control System 8 15-01-2009 10:39
Driver Station Login Mr-Shutter FRC Control System 2 12-01-2009 23:36
2nd Driver Station bcharbonneau General Forum 2 09-01-2009 14:19
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
