Go to Post So go out and learn something new, even if it is old. Co-operate in this and you'll get much more out of it. Cheat and you are only cheating yourself. - ChrisH [more]
Unread 19-01-2009, 15:56
gokul gokul is offline
FRC #0571
gokul is an unknown quantity at this point
Re: WindRiver Programming
Originally Posted by dnrobotics11 View Post
How do you compile the different class templates such as the camera and the gyroscope with the main template into a single program download to the cRIO? Are these compiled independently? Which manual is best for these questions for WindRiver programming and downloading?
Start with a base program.
Then copy the files from other projects to this new project's folder (in the workspace).
Make sure you copy the correct .h files also - you need only .cpp and .h files.
Now, you will have to make sure that the key START_ROBOT_CLASS statement is ONLY in your main program and no place else. It should also reference your program (class) only.
By #include'ing correct .H files and referencing the correct classes/methods from the other files you should be able to get a good build.
Hope this helps!
WindRiver Errors ExarKun666 C/C++ 7 04-03-2009 20:32
Windriver LAC McGurky C/C++ 12 25-02-2009 18:38
Getting Familiar with Programming in WindRiver kyungjin C/C++ 35 17-01-2009 13:04
compiling in windriver koreabell Programming 4 05-01-2009 15:32
