Go to Post Well, there goes my strategy of blowing out the opponent and then committing flagrant safety and sportsmanship violations to keep the margin close :D - Jared Russell [more]
Unread 19-01-2009, 16:46
sloteera's Avatar
sloteera sloteera is offline
AKA: Rafa
FRC #1860 (Cephatron)
sloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud ofsloteera has much to be proud of
Help: "Setup Axis Camera"
Hi...
Please, we already read all threads, manuals, posts about this but we can't solution our problem.
I'll try better:
We already set the Computer IP for static (192.168.0.1)
We already turned off the firewall
We can access the camera by browser with the IP 192.168.0.90...
Already a reset on the camera..
We are using the username "FRC" and password "FRC"...
But we can't open the camera with Labview..
Please, some team that passed by same situation, help us...
By the way.... thanks
Unread 19-01-2009, 16:51
Fish2977's Avatar
Fish2977 Fish2977 is offline
Biscuit Team Leader
AKA: Butcher Pete
FRC #2977
Fish2977 is an unknown quantity at this point
Re: Help: "Setup Axis Camera"
have you set your subnet mask to 255.255.255.0?
Better be Bonzo.
Unread 19-01-2009, 17:12
sloteera's Avatar
AKA: Rafa
Yes, we did everything that was said in the manual, still unable to access the camera by the "Setup Axis Camera" and "Visio Assistant"
Unread 19-01-2009, 19:05
Team2883's Avatar
Team2883 Team2883 is offline
FRC #2883
Team2883 will become famous soon enoughTeam2883 will become famous soon enough
You have power I presume, did you update the crio and reimage. Also did update your software. after updating software and reimaging you can access the robot main and the dashboard deploy the robot main and the run the dashboard if you have all of the proper IP's then it should work good luck
Unread 19-01-2009, 19:09
sloteera's Avatar
AKA: Rafa
But at the first moment, I want to access the cam via PC (Setup Axis Camera e Vision Assistant)...
I don't try yet, connect the cam with the cRIO.
My computer is correctly configured but I can't access the cam
Unread 19-01-2009, 19:33
Team2883's Avatar
FRC #2883
What is your computer configured to. what cable are you using is it a cross over cable? can you gain access to the camera in your browser.
Unread 15-01-2010, 18:36
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
When I set the computer's IP to 192.168.0.3 and navigate to 192.168.0.90 in Firefox, I can log in to AXIS (username FRC, password FRC) and view the camera. Our LabVIEW code says the camera is at 192.168.0.90, which is correct, but we're getting "Timeout in Camera Communications" on the DS. What I'm thinking is that the LabVIEW code needs to know the password somewhere... should I replace the IP with FRC:FRC@192.168.0.90 or something?
Unread 15-01-2010, 18:45
It is not necessary to change the address to include the login info.
What other symptoms do you have?
Greg McKaskle
Unread 15-01-2010, 19:03
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Not sure if this is your problem, but what solved the no feedback on my end (and for a few others as well) was running the DS update and having it uninstall everything and then running it and reinstalling.
Unread 16-01-2010, 00:59
Red987 Red987 is offline
FRC #0987
Red987 is an unknown quantity at this point
ok, i havnt actually tried enabling the camera in LabVIEW code, but in C++ code there are code lines that have to be added and adjusted in order for it to work correctly. There might be some function blocks that have to be put in order for it to work through the crio.
Setup Axis Camera - ERROR Bruno Inácio Technical Discussion 2 16-01-2009 12:37
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
Camera never finds target, stays at "Searching..." Mike Programming 12 22-01-2006 12:47
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
