Go to Post All the gangstas in FRC have solid gold CRios. It's called "blingage". If you don't have a solid gold CRio, you're not a straight-up G. :D - Jamie Kalb [more]
Unread 19-01-2009, 16:49
nekng's Avatar
nekng nekng is offline
Former 1836 Captain
AKA: Nate
FRC #1836 (MilkenKnights)
nekng is on a distinguished road
Driver Station Screen Fails on Connecton to Robot
The display on my team's drive station shuts off when a wireless connection is established between it and the robot. We are running the updated image on the DS and on the robot we are running the updated default windriver code. Does any else have this problem?
Unread 19-01-2009, 20:51
nekng's Avatar
Former 1836 Captain
AKA: Nate
Re: Driver Station Screen Fails on Connecton to Robot
Actually, it is not just when the DS connects to the robot, it seems that the screen fails randomly from 10seconds-2minutes after boot. It is only the screen that fails, everything else keeps working.
Unread 19-01-2009, 21:11
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
There have been reports of static discharge causing the screen to go out. Is your work area particularly dry? That could lead to frequent static discharges onto the DS.
Unread 20-01-2009, 01:36
nekng's Avatar
Former 1836 Captain
AKA: Nate
Not only is our work area really dry, but the floor is covered with carpet so that makes a lot of sense.
Dead Driver Station? tdeprince FRC Control System 3 12-02-2009 12:14
Driver Station Login Mr-Shutter FRC Control System 2 12-01-2009 23:36
Driver Station Blank Screen, Anyone have the same problem? LDavies562 FRC Control System 14 22-12-2008 19:34
Driver Station Setup?? Team 1708 Dave Programming 9 19-12-2008 23:09
driver station doesn't see robot nickmagus Programming 4 29-11-2008 23:58
