Go to Post Andy Baker's breakfast of choice is Kellog's Nuts and Bolts. - Adam Y. [more]
Unread 16-01-2009, 15:11
Re: Yet another bumper thread
Originally Posted by Joe Ross View Post
Maybe I'm missing something, but isn't it already allowed to extend the soft parts of the bumpers? See <R08-J> and illustrated in figures 8-2 and 8-4?
And Q&A has clarified that, for the 6"-max robot length requirement, you have to have the backing 6" long, but you can have soft parts extending beyond said length that are part of the bumpers but not counted in the length. http://forums.usfirst.org/showthread.php?t=11316
So you are correct.
Unread 16-01-2009, 15:19
GaryVoshol's Avatar
Cogito ergo arbitro
If you want to follow the letter of the law, by building the kit frame as illustrated in the picture, you have actually created a very short 45-degree angled face to your BUMPER PERIMETER - somewhere in the neighborhood of 1.4 inches. This face has no frame backing to attach the BUMPER to. Never mind that you can't attach a 6" bumper to a 1.4" space.
Somebody please ask Q&A how to BUMPERize this corner. Following instructions given with kit parts should not lead you to violating the rules.
(since 2004)
Unread 17-01-2009, 08:21
Gdeaver Gdeaver is offline
FRC #1640
The kit frame can be built with out that corner gap. For other reasons we could not have that gap.
Unread 17-01-2009, 14:08
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Yes, it is possible to build the KOP chassis without the corner gap, our frame does not have this gap. However, the directions do specify this gap and I agree with Gary that providing teams with a kit that requires significant modification outside the provided directions in order to be a competition legal frame is not overly helpful to veterans and may even be detrimental to rookies.
The heads of the axle bolts I mentioned in my initial post are also visible in the picture posted by Kevin. These bolt heads are significantly thicker than the angle we would be using to clamp the fabric to the bumpers. My uneducated opinion also says that mounting the bumpers with this frame rail as the "support" and those bolt heads being the only actual contact with the plywood would cause them to be much MORE likely to break not less. A large impact occurring near one of these bolt heads would transfer the force through the small area of the head itself which would likely cause the plywood to crack wouldn't it?
Squirell, that sounds like it could be the easiest solution. Depending on what the GDC says regarding this question we will definitely look into this possible solution.
Unread 19-01-2009, 02:31
This year, the GDC has allowed pockets for bolts, etc.
http://forums.usfirst.org/showthread.php?t=11389
Unread 19-01-2009, 10:08
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Thanks for pointing that out, Eric, it'll save us some work.
Unread 19-01-2009, 10:40
Fe_Will's Avatar
Fe_Will Fe_Will is offline
AKA: Will
FRC #0955 (CV Robotics)
Fe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud ofFe_Will has much to be proud of
I don't understand why so many people are complaining about the kitbot. It is not intended to be an end-all-be-all solution but a starting point so teams can get something moving. It is a good way to get programmers started early in the build season and to have a moving base to prototype pieces for game function on, I'll admit.
I feel like some people have forgotten (or don't remember) the time when kitbots didn't exist.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." -Aristotle
Unread 19-01-2009, 10:44
MrForbes's Avatar
AKA: Jim
Or they weren't involved with FIRST yet.
Unread 19-01-2009, 10:51
Fe_Will's Avatar
AKA: Will
"Well, back in my day you got some 2x4 aluminum tube, wheels, and a couple of drills..."
Sometimes I forget how long I've been involved with FIRST.
Unread 19-01-2009, 11:30
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I hate to be the bearer of bad news, but if a team is trying to make their bumpers clear a protrusion on the robot, then by definition, that protrusion forms part of the perimeter. Bumpers have to follow the contours of the perimeter.
I fully support the idea of FIRST issuing a clarification on this subject. It's just that I don't think this is a good interpretation of the rules. It's particularly bad, because although the answer is technically correct (there is no such direct prohibition), the rest of the bumper rule makes this technique at best useless, and in pretty much all cases, illegal (because of the perimeter requirement in combination with the minimum bumper coverage and length).
This could be salvaged, however, by loosening the requirements a little bit: just as they stated (in a Q&A, not an update) that a little gap between the bumper and its supporting structure was (sometimes) legal, they could clarify that bumpers don't always have to follow the perimeter, in cases of small protrusions. Put these two things in an update, and everybody's interests will be satisfied. (Of course, some suitable definition of a small protrusion is necessary here, to avoid neutering the perimeter clause completely.)
I also think that it's interesting to hear that the GDC no longer feels that this will introduce undue weakness into the bumper. (This was their rationale for the 2008 prohibition on this design feature.) Do they believe that requiring a structural element to span the entire bumper alleviates this concern? I never personally felt that this was a structural issue, except in extreme cases, and I would have preferred FIRST to either define a strict requirement in the rules, or conversely, give inspectors latitude to determine what is and is not strong enough. The former has the advantage of maintaining consistency, while the latter is at least forgiving to the teams and the officials.
Incidentally, the rulings last year depended on teams reading the one or two Q&As out of hundreds that dealt with this topic, and noting that for the particular case of the 2008 bumper rule, the Q&A was clarifying an existing requirement (teams must build to the bumper specification), and not making up a new restriction (which would be dubiously valid). That's a fine point, but under last year's rules, the teams were expected to follow it.
Unread 19-01-2009, 12:48
jgraber jgraber is offline
jgraber is just really nicejgraber is just really nicejgraber is just really nicejgraber is just really nice
Originally Posted by Don Rotolo View Post
If you do ask, I'd love to know if one is permitted to machine small depressions into the back of the bumper, not exceeding 1/4" depth, exclusively to provide clearance for these fasteners so the bumper fits more snugly against the length of the chassis member/frame.
That was allowed. In addition to the Q&A response, you could argue that it was part of an interlocking bracket bumper attachment/alignment mechanism.
Official bumpers have aluminum angle top & bottom, so they might rest against the chassis and not wood.
I was considering sewing the bumper fabric into a tube around the plywood and noodles, rather than using clamping angles. Does this seem like a good idea or not?
Unread 19-01-2009, 17:04
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
You may want to ask the Q&A to verify that this is allowed. Currently it would appear to be prohibited by <R08>
.... To achieve this, BUMPERS must be constructed as described below and illustrated in Figure 8 – 1.
If you look at Figure 8-1 it includes the aluminum angle although the text itself makes no mention of the angle or specifications for it.
If you do sew it I would recommend also using staples on the back of the bumper to hold it in place. My team has used staples alone the past two years and never had a problem.
Another Bumper concideration Wayne Doenges Rules/Strategy 8 20-02-2007 06:58
Yet another website to critique Joshua May Website Design/Showcase 11 18-10-2004 09:18
yet another joystick question Stormhammer Rules/Strategy 2 19-01-2004 10:10
Yet another illustrator question ryan_f Computer Graphics 3 02-09-2003 16:10
Yet another scoring system... archiver 2001 0 23-06-2002 23:26
