Go to Post There's too much whining lately.. we need a hug forum - Gadget470 [more]
Unread 19-01-2009, 17:33
emhw1994 emhw1994 is offline
FRC #2458
emhw1994 is an unknown quantity at this point
Robot Carts
I was wondering where we could get a robot cart. I am kinda an amateur at this whole robotics thing so if someone could help me out that would be great!!!!!!!
Unread 19-01-2009, 17:50
Re: Robot Carts
Simple: Go to your local hardware store. Find a furniture dolly. When you get it back to your build area, add a handle.
Better: Garden supply store, get a cart. Bigger tires and a raised workbed. Better for going over those pesky cable covers.
Best: Custom cart that can go over said cable covers, with rails for the robot, toolboxes, etc.
I'd go with the garden-type cart, at least for now. You could modify it later.
Unread 19-01-2009, 17:52
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Re: Robot Carts
As far as I know your supposed to make your own, but I guess you could find something big enough somewhere...Try home depot or something but I recommend you build your own. There like 10x cooler
Re: Robot Carts
Or if you guys want some help with materials for a cart just PM or IM me. We have a ton of 80/20 sitting around if you need it.
We're in Mount Olive.
Nope
Unread 19-01-2009, 17:54
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Robot Carts
Do a search here on CD and you will see threads and pictures about carts.
Most teams build their own, they run from simple to hovercrafts with everything in between.
But this has always been my favorite:
GeoffP GeoffP is offline
Engineer
FRC #1222 (Falcons)
GeoffP is an unknown quantity at this point
Re: Robot Carts
we went to lowes and bought a garden cart. it has 8" pneumatic tires and a robust flat wire mesh surface and no sides and is robust enough to hold the robot and control board.
good luck
Unread 19-01-2009, 17:55
Re: Robot Carts
Nah, you don't have to make your own. It's ideal because you can customize it to suit your team's needs, but it's better as an offseason project.
I suggested a slightly modified garden cart. Here's the main modification I'd make: take a pair of short 2x4s and attach them to the bed of the cart so that the wheels of the robot are off of the cart. Now it's also a testing platform.
Or you could use a little red wagon...
Unread 19-01-2009, 17:57
FRC #2458
Re: Robot Carts
Akash Rastogi- cool, how should i IM you?
Unread 19-01-2009, 18:05
AKA: Brandon Liatys
Re: Robot Carts
heheh...I just had an awesome image of a cart with pneumatic cylinders on the wheels....low rider robot
[/offtopic]
look in his user profile it has AIM and Yahoo contacts.
Unread 19-01-2009, 18:33
Re: Robot Carts
IM me at lilstogi if you wish.
Unread 19-01-2009, 18:49
Tom I's Avatar
Tom I Tom I is offline
Slightly Crazy... slightly
AKA: Tom Indelicato
FRC #0811 (The Cardinals)
Tom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to beholdTom I is a splendid one to behold
Re: Robot Carts
I'd highly recomend pneumatic wheels. It makes going over bumps such as cables very easy, and your bot has less chance of keeling over. I'd also recomend rails to get the robot off its wheels... This makes testing easy, specially autonomous. A place to put an O/I also helps a ton! Everything else is just for show, (although flashy lights are pretty!!!)
Unread 19-01-2009, 19:04
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: Robot Carts
While it's best to do this as an off season project, we find the cart to make a big difference in the pit. We built this one last build season and it's being motorized for this year.
The cart shown lets us work on the robot at convenient work height and then lower it to clear doors. We have a deep cycle battery and 3000W inverter for power tools and charging up to 3 batteries in the cart on the move.
Unread 19-01-2009, 21:43
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: Robot Carts
Our cart was thrown together one day when we were bored, ours is pretty much all 2x4s and plywood. Although when we go to Atlanta or other far away competitions we go with the simpler four 2x4s bolted together in a box and four casters, which works very well.
Unread 19-01-2009, 22:07
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Robot Carts
We got our sponsor Valley Iron to donate 2k for our new 2009 cart. The main reason was because it was the freshman project. That's why they donated so much money. A pic of our can be found on cd just search frc1323 in the media section. The cart is almost done.
R.C.
MadTown Robotics Team 1323
Unread 19-01-2009, 22:55
spazdemon548's Avatar
spazdemon548 spazdemon548 is offline
FRC #0548
spazdemon548 has a spectacular aura aboutspazdemon548 has a spectacular aura about
Re: Robot Carts
If your looking for ideas, here's ours from last year...
Powered Robot Carts Racer26 General Forum 29 07-12-2011 12:05
Robot Carts Josh Goodman Technical Discussion 22 29-01-2008 15:52
Motorized Carts Andy B Technical Discussion 19 17-01-2007 08:10
Robot shopping carts follow you around JohnBoucher Chit-Chat 7 10-08-2006 18:09
Robot Carts oracle_nick General Forum 38 01-03-2003 13:27
