Go to Post "It's robotics season; I no longer know what sleep is." - StephLee [more]
Unread 19-01-2009, 16:38
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
problem with TwoColorTrackDemo-v2
i tryed to download it to the CRIO but the camera doesn't track the target
the servos turned and moved ... but the camera doesn't find anything
Unread 19-01-2009, 17:03
Booksy Booksy is offline
FRC #1244 (Viking Robotics)
Booksy will become famous soon enoughBooksy will become famous soon enough
Re: problem with TwoColorTrackDemo-v2
what does the mask show?
My favorite CD quote ever(taken out of context of course):
Originally Posted by ttldomination
water would be hard to build
Unread 19-01-2009, 17:21
mahmosh's Avatar
FRC #1946
which mask do u mean ?
Unread 19-01-2009, 19:54
The one under the camera image. Does it show any red or green blobs?
Unread 19-01-2009, 20:41
cabbagekid2 cabbagekid2 is offline
#0368 (Kika Mana)
cabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura aboutcabbagekid2 has a spectacular aura about
Make sure you check to see if the "find foe" button is selected or not on the front panel. The problem we had was that we selected a color for "friend" from the display-example green on top, pink on bottom but what we didn't see was that we were set to track "foe". This is why even though we were seeing the correct colors in the mask our camera wouldn't track it (since it was set to track foe and not friend).
Unread 20-01-2009, 09:30
mahmosh's Avatar
FRC #1946
YEAH ... it shows green blobs !! so what the problem ?
I'm using Windriver not Labview !!
Problem With CD-Events Jeff Waegelin CD Forum Support 4 25-01-2007 21:07
Problem with gyro... capenga Programming 21 16-02-2006 19:25
Problem with MPLAB d.courtney Programming 5 02-02-2005 21:42
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Problem with OI / RC Jay Lundy Technical Discussion 2 29-03-2002 23:07
