Go to Post Is it legal to build 2 robots? yes. Is it crazy to do so? maybe. - Andy Baker [more]
Unread 19-01-2009, 20:01
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Using driver station digital inputs
The digital and analog I/O on the driver station are for the purpose of creating custom UIs for the robot. It is true that there are no pull-ups on the digital inputs, so you have to explicitly do that yourself or you'll get unpredictable results. You can also do tricks like use a set of resistors and a switch to use one of the analog inputs as many digital (switch) inputs if you're running out of real digital inputs.
Be aware that in the future it is possible that you will not be able to read the driver station values during the autonomous period. So plan on writing the code to store values in variables during the disabled period before autonomous then use them in the autonomous period.
Brad Miller
Robotics Resource Center
Flashing Driver Station Digital Input MacGyver1718 FRC Control System 3 15-01-2009 19:22
Interrupt on driver station digital input Nameless Programming 9 04-12-2008 16:55
Using Analog Inputs as Digital (on the OI) Guy Davidson Control System 16 10-03-2008 17:17
digital inputs: some bad? Trav-O Electrical 3 18-02-2008 23:29
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
