problem with TwoColorTrackDemo-v2
i tryed to download it to the CRIO but the camera doesn't track the target
the servos turned and moved ... but the camera doesn't find anything ![]() |
Re: problem with TwoColorTrackDemo-v2
what does the mask show?
which mask do u mean ?
The one under the camera image. Does it show any red or green blobs?
Make sure you check to see if the "find foe" button is selected or not on the front panel. The problem we had was that we selected a color for "friend" from the display-example green on top, pink on bottom but what we didn't see was that we were set to track "foe". This is why even though we were seeing the correct colors in the mask our camera wouldn't track it (since it was set to track foe and not friend).
| Problem With CD-Events | Jeff Waegelin | CD Forum Support | 4 | 25-01-2007 21:07 |
| Problem with gyro... | capenga | Programming | 21 | 16-02-2006 19:25 |
| Problem with MPLAB | d.courtney | Programming | 5 | 02-02-2005 21:42 |
| Problem with communicating with STAMP through serial port | Skabana159 | Technical Discussion | 2 | 06-02-2003 21:10 |
| Problem with OI / RC | Jay Lundy | Technical Discussion | 2 | 29-03-2002 23:07 |
