Go to Post make your robot so it's not a problem and it won't be a problem - pfreivald [more]
Unread 18-01-2009, 23:56
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
pic: 16 wheeled bot?
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Re: pic: 16 wheeled bot?
so this is why AM was sold out of rover wheels
Unread 19-01-2009, 00:06
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Is this for a bot and a practice bot, or just one bot?
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
Unread 19-01-2009, 02:41
Andy L's Avatar
FRC #1458
check the next pic
two robots, normal and practice
four swerve modules each two wheels per module
Unread 19-01-2009, 20:54
WhiteShadow1474's Avatar
WhiteShadow1474 WhiteShadow1474 is offline
FIRST. Much better than SECOND.
AKA: Jason
FRC #1474 (Master Link Militia)
Team Role: Student
WhiteShadow1474 is an unknown quantity at this point
oh! i see. making omni wheels with the rover wheels. 4 wheels around one shaft at one corner. its perfect!
Poor minds discuss gossip. Brilliant minds discuss ideas.
Unread 20-01-2009, 11:12
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I was actually drawing up a robot the other day with 16 rover wheels, but the weight of ~125 in. of chain on ONLY one side to drive 8 of them kinda put a damper on my plans.
I'll be interested if your concept is the same as mine (but probably not, since my ideas tend to be a bit far fetched (albeit perfectly legal by the rules).
Oh wells.
Edit: Oh, omni... Definitely not the same concept. HA! There's a shock. lol
Unread 30-01-2009, 22:18
5n1p3r's Avatar
5n1p3r 5n1p3r is offline
IM 5n1p3r
AKA: Matthew
FRC #0714 (Team Panthera)
5n1p3r will become famous soon enough5n1p3r will become famous soon enough
Send a message via AIM to 5n1p3r
do you plan to use all of these
pic: Nah, We just have a set for the Alpha bot and the beta Bot Kevin Ray Extra Discussion 10 25-01-2009 18:40
3-wheeled robots Gearheads1 Technical Discussion 16 08-01-2009 15:32
5 Wheeled Robot? Rion Atkinson Technical Discussion 6 07-01-2009 21:13
pic: Team 241: This Years Bot Lifting Last Years Bot Dantvman27 Robot Showcase 3 21-02-2007 07:04
2 wheeled balancing robot John Gutmann Technical Discussion 16 26-08-2005 14:21
