Go to Post Shouldn't we be encouraging exploration instead of repeatedly beating it with a stick? - Mike Soukup [more]
Unread 19-01-2009, 15:23
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Gearbox selection
Hi all,
I'm looking for some planetary-type gearboxes at a reasonable cost, and I'm considering using the 2007-KOP gearboxes. However, I heard that there were some issues with these (stripping gears...???), and then those issues were corrected. Anyone here know the validity of this, and if there's an easy way to identify the corrected version? Also, is the correction something easy to do, with easily available parts (perhaps swap some gears to metal, etc)?
Cheers,
-Neil.
Unread 19-01-2009, 15:30
Jared Russell's Avatar
Taking a year (mostly) off
Re: Gearbox selection
The problem with the 2007 BaneBots gearboxes was due to an (apparently) brittle carrier plate. Those with a hardened carrier plate can be identified with "-HC" at the end of their part number sticker. That said, plenty of teams used the gearboxes without any issues that year (especially if you support the end of the shaft with a bearing rather than cantilevering the load).
Other planetary gearboxes that fit the CIM include:
-Banebots P80 series (http://banebots.com/c/P80A-nnnn-n0n5)
(14 reductions between 3:1 and 256:1)
-AndyMark GEM500 (http://andymark.biz/am-0270.html)
(Each level is a 3.67:1 reduction; you can stack as many levels as you want for more reduction)
Unread 19-01-2009, 15:39
CraigHickman
Posts: n/a
It's barely different. The casing is a little different sized (bigger, I think?), and it's got some more bolts running along it. Otherwise, the Banebots are excellent gearboxes that have now undergone much more testing than their first forte into FIRST.
That being said: my team is using 4 of the Banebots gearboxes. They're small and reliable, and just the PERFECT speed for us.
Unread 19-01-2009, 19:52
VEI Dude's Avatar
Mentor 4024, 4013
Excellent info, thanks. The planetary that banebots is selling now do have the -HC, and I expect to have just a gear on the end, so it sounds like the way to go. I did see/evaluate the P80 and GEM500, but cost is a major issue (plus we'll want to get one spare, so the cost difference multiplies fast).
Craig, are you using single-speed?
Cheers,
-Neil.
Unread 19-01-2009, 20:51
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
I am not so sure that you can use the 2007 KOP BaneBots Gearboxes on a legal 2009 FIRST robot, we looked into it but decided that rule R-32 prohibits this course of action.
<R32>
COTS ITEMS from ROBOTS entered in previous FIRST competitions or COTS MECHANISMS that are no longer commercially available may be used under the following conditions:
B.
The item must not be a part custom made for the FIRST competition and provided in the Kit Of Parts for a previous FIRST Robotics Competition (e.g. 2006 FRC transmissions, custom-made motor couplers, custom sensor strips, 2006 IFI CMUcam II modules, etc. are not permitted),
Its a pain because we have 4 or 5 of them collecting dust... Either way, they are a robust piece of kit (unless you drive them with 2 CIMs each at a huge hunk of Aluminium and smash straight into it repeatedly... ). The P80s look okay and the GEM 500 does too if you can afford them.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 19-01-2009, 21:15
They are a current COTS item, not custom made for FRC. Thus, <R32-B> does not apply.
Unread 19-01-2009, 22:32
VEI Dude's Avatar
Mentor 4024, 4013
Yep, my interpretation of R32 is that they also would've had to have been entered in a previous competition, and I found out that we gave them to another team in 2007 (this is my first year with FIRST).
My intention is to purchase from Banebots now, but ,4lex S. if you want to sell yours, let me know.
Cheers,
-Neil.
Unread 19-01-2009, 22:37
CraigHickman
Posts: n/a
Cheers,
-Neil.
Yeah, I'm doing Single Speed. Though there was a CAD project I did a while back that added a simple 2 speed option to a Banebots... It's a bolt on final stage. If you need multiple speeds, but don't have the space, it's totally doable. (and another hint: Your second "speed" doesn't need to be attached to the wheels, maybe to a winch, or some other mechanism.)
Unread 19-01-2009, 23:37
I'd second the suggestion for the BaneBots.
We've never had problems with them in our experiences. great boxes.
Unread 20-01-2009, 15:36
,4lex S.'s Avatar
University Mentor
AKA: Alex Strong
They may be a current item available at BaneBots, but on the site it says that:
We recently found a few boxes of these - take advantage of our find with a great low closeout price.
In the definition of vendor, FIRST requires:
The VENDOR makes their products available to all FIRST Robotics Competition teams. VENDORS must not limit supply or make a product available to just a limited number of FIRST Robotics Competition teams.
Since BaneBots has a presumably low number of boxes available, I do not think they would be considered a legitimate vendor for this product. No offence intended to BaneBots of course. This does not reflect on the quality of the product, but the availability.
Unread 25-01-2009, 10:55
VEI Dude's Avatar
Mentor 4024, 4013
,4lex S., good observation. I have been trying to register on the usfirst forums for a few days now to ask about this to get a definitive answer, but the registration process is failing. Can someone do me a favor and ask this question on those forums, please. Much thanks!
Unread 28-01-2009, 18:59
Nick 568 Nick 568 is offline
FRC #0568 (The Nerds of The North)
Nick 568 is on a distinguished road
Send a message via AIM to Nick 568 Send a message via MSN to Nick 568 Send a message via Yahoo to Nick 568
Has anyone received a difinitive answer as to if the BB boxes are allowed this year? One design we're thinking of, it would be very convenient to use our 4 BB boxes.
1885- 2006 VCU Rookie All-Star, 2006 Palmetto All-Star, 2006 Championship Rookie All-Star
568- 2005 Woodie Flower's Award, 2006 Davis-Sacramento Judge's Award, 2007 SVR Judge's Award
Unread 28-01-2009, 19:02
You don't need a forum ID to look at the Q&A.
http://forums.usfirst.org/showthread.php?t=11555
In other words, they better have the hardened carrier plates.
Unread 28-01-2009, 21:02
,4lex S.'s Avatar
University Mentor
AKA: Alex Strong
Thanks for that clarification, sorry to introduce any confusion into the matter. The annoying thing for us is that we destroyed half our boxes in competition in '07 and all the parts are mixed together in a box... I really have to get my team on top of that Q and A thing. My apologies.
Unread 02-02-2009, 00:23
Paul11 Paul11 is offline
FRC #1245
Paul11 is an unknown quantity at this point
Our team used the HC Banebots boxes that came in the kit 2007 and we were very pleased with the performance. They did not break at all and we were not supporting the other end of the axle. If it is allowed I would highly recommend these boxes as they helped our team to the regional semifinals that year.
Offseason gearbox project... maybe this gearbox has helical gears? Travis Covington Technical Discussion 17 05-06-2006 11:48
Driver Selection Mousepad General Forum 23 26-02-2005 18:36
Motor Selection vtome Motors 2 11-01-2003 09:50
DRIVER SELECTION.... archiver 2001 11 24-06-2002 00:02
Driver Selection archiver 2000 7 23-06-2002 22:05
