Go to Post If Will uses the word "dope", doesn't wear a larger FIRST logo, takes up half of the St. Louis arena, if there was not enough seating in the pits, if the music was killed during finals, it was all justified tonight. - Barry Bonzack [more]
Unread 24-06-2002, 01:01
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Joystick max VS. motor max
Posted by Veronica at 2/17/2001 9:21 AM EST
Student on team #27, Team Rush, from Osmtech and Textron.
I remember reading somthing about the joysticks going to 254 but the motors maxing out at around 158. can anyone tell me where to find this post or confirm the number for me? I looked through the archives but was unable to find it. Thanks
V
#0047 (ChiefDelphi)
Not exactly...
Posted by Nate Smith at 2/17/2001 1:19 PM EST
Other on team #66, Frostbite, from Willow Run High School and GM Powertrain.
In Reply to: Joystick max VS. motor max
Posted by Veronica on 2/17/2001 9:21 AM EST:
: I remember reading somthing about the joysticks going to 254 but the motors maxing out at around 158. can anyone tell me where to find this post or confirm the number for me? I looked through the archives but was unable to find it. Thanks
: V
Without my manual handy to look these things up, it sounds like you're actually referring to the minimum power needed to start the motors rolling...because of the frictional forces and everything else, if you set a PWM to 128 (or 126 for that matter) you're not going to get a robot who's standing still to get moving...you may be referring to something else though, I dunno for sure...too busy building our box lately to follow much else...
Nate
#0047 (ChiefDelphi)
#0047 (ChiefDelphi)
Re: Joystick max VS. motor max
Posted by Lloyd Burns at 2/18/2001 9:36 AM EST
Engineer on team #188, Woburn Robotics, from Woburn Collegiate and TorDistSchoolBrd, ScotiaBank. OntPwrGen, Enbridge.
: V
. Depending on your joysticks you may not be able to get the full number (the controller is counting a time related to you joystick's resistance). Most joystick pots (the sensing element) have all the resistance in a patch at the centre, and when you get to, say 3/4 of the way to max position, the resistance stops changing.
If your element is low resistance, you may not reach 254. If your element or the wiper going to it is not great, you may never reach 0.
. I just tested the Blue Victor I have here, which I don't think has been recalibrated (see below) and I found that the output was nil from 127 to 137 (written into a test program), and then changed in linear fashion up to 218, approximately, at which point it was full on (not switching).
. Perhaps what you really want to know is that by using the calibration switch on the Victor you can change the response, somewhat, from the factory setting. Read the Victor Information .pdf from InnoFirst.
. Hope this helps.
#0047 (ChiefDelphi)
Posted by Veronica at 2/19/2001 4:32 PM EST
In Reply to: Re: Joystick max VS. motor max
Posted by Lloyd Burns on 2/18/2001 9:36 AM EST:
The question originated from some false information thanks for the help, we are clear, bad info can cause issues lol but hey that's what you guys are here for right to clarifiy these things
V
: : I remember reading somthing about the joysticks going to 254 but the motors maxing out at around 158. can anyone tell me where to find this post or confirm the number for me? I looked through the archives but was unable to find it. Thanks
: : V
: . Depending on your joysticks you may not be able to get the full number (the controller is counting a time related to you joystick's resistance). Most joystick pots (the sensing element) have all the resistance in a patch at the centre, and when you get to, say 3/4 of the way to max position, the resistance stops changing.
: If your element is low resistance, you may not reach 254. If your element or the wiper going to it is not great, you may never reach 0.
: . I just tested the Blue Victor I have here, which I don't think has been recalibrated (see below) and I found that the output was nil from 127 to 137 (written into a test program), and then changed in linear fashion up to 218, approximately, at which point it was full on (not switching).
: . Perhaps what you really want to know is that by using the calibration switch on the Victor you can change the response, somewhat, from the factory setting. Read the Victor Information .pdf from InnoFirst.
: . Hope this helps.
[IMG] code is Off
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
joystick problem archiver 2000 12 23-06-2002 23:08
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
