Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 19-01-2009, 22:56
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Have you burned your reciver?
it is definitely fried. we are a new team and got to excited because we have been trouble shooting for about 16hrs, so we could not wait and stuck it in the 20 volt on and it did not work like i said. we rewired it with the wall charger and plunged it in nothing happened. So seriously there is no way to fix it we have to buy a new one for $100? Linksys will not donate another one or first will not supply one?
Unread 19-01-2009, 23:00
ROFLcopter's Avatar
ROFLcopter ROFLcopter is offline
who was phone
AKA: Robert Grizzell
FRC #2364 (Oregon RoboHawks)
ROFLcopter is on a distinguished road
Send a message via AIM to ROFLcopter Send a message via MSN to ROFLcopter Send a message via Yahoo to ROFLcopter
I can almost guarantee you that they won't. US First was the purchaser of the Bridge, so they own the warranty. You going to have to buy another one.'
And just to let you know, the side of the power cable with the white stripes in positive. I would hate to see you fry another.
This signature has been removed in accordance with City Ordnance law L34.B3. If you feel this signature has been mistakenly removed for reasons not within the guidelines of L34.B3. Visit the City Courthouse #3 and file a report.
Unread 19-01-2009, 23:48
repairmanray repairmanray is offline
repairmanray can only hope to improve
If I understand correctly, you plugged it into 20 volts? If so, it may be possible for you to take it to a repair shop, or find someone who knows electronics who can repair it. It may just be a burned up voltage regulator.
Like all great art, it appears simple, until you try it.
Unread 20-01-2009, 11:55
This may very well be a $90 lesson in reading the manual first. Please read section 3.2 of the FRC Control System manual so you do not destroy your replacement bridge.
However, do not be so hasty in assuming that all hope is lost. I have reverse biased the WGA600N adapter without destroying it. I have also pushed 24V into it without destroying it. However, I might have just been lucky, and I do not recommend doing either. I performed both of these tests using the regulated supplies on the PD, hooking it direct to your battery through a 20A breaker might have blown something - I really don't know, and I really don't have the extra bridges to find out.
In short, go read those sections, hook it up correctly, and see if it works.
Unread 20-01-2009, 13:31
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
http://forums.usfirst.org/showthread.php?t=10842
also, this link shows how to connect things. Could be helpful in the future. Be sure to alway's consult the rules.
http://usfirst.org/uploadedFiles/200...%20diargam.pdf
Unread 20-01-2009, 17:19
okay one more time
We hooked up to the 20 volt slot
my dad is bring it to a guy that can take a computer complty apart and put it back together sometimes better than new
Unread 20-01-2009, 17:28
There is no 20V slot. There is a 24V, a 12V, a 5V and a bunch of unregulated ones. What does the connector's silk screen say?
Unread 20-01-2009, 18:29
okay i do not know where we plugged it in but it was in a slot that said 30volts right next to it and we put in a 20volt breaker. sorry i am a programmer not an electrician.
Unread 20-01-2009, 19:28
ROFLcopter's Avatar
who was phone
I just want to clarify you that what you are looking at are Amps not Volts. Fuses only go by amps. The voltage will be displayed elsewhere on your Power Distribution block.
We're here to help you Tomy, not to criticize.
Unread 20-01-2009, 19:33
okay if you look at a power distribution bot we put it one that says 30A max and we firgured out that we put the poles backwards
Unread 20-01-2009, 20:11
In many dc devices, there is a diode placed across the power supply input, which is supposed to cause a short and blow a fuse if you reverse polarity. If you reversed polarity and had too high of a breaker, it may have just burned open the pcboard trace and possibly left the diode shorted as well. You may be able to remove or replace the diode, fix the trace, and be good as new.
Unread 20-01-2009, 20:16
i had my dad bring it to a guy that can make a computer for twigs and leaves. he said we blew a chip or something .... so that means we have to get a new one right?
Unread 20-01-2009, 20:21
Maybe not. Can you get any numbers off the component? Maybe take a picture of it? Depending on what the component is, you may be able to make a trip to radio shack, and with a little soldering iron work, fix it.
What Do You Wish You Would Have Known Your Rookie Year? SlaminSwimster General Forum 77 16-12-2008 12:13
What do you call a sale at your house of items that you have? Elgin Clock Chit-Chat 52 07-06-2005 17:44
Have you named your robot? Modeish General Forum 123 13-03-2005 08:27
Have you found your TIER? Rich Wong General Forum 2 30-10-2003 18:53
Have you seen your robot...yet? Steve Yasick General Forum 9 01-05-2003 19:53
