Go to Post So we get to hear the likes of Copioli, Baker and Patton yuk it up? This should be good. - Ricky Q. [more]
Unread 20-01-2009, 00:12
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Pressure regulator
Originally Posted by Perci321 View Post
Does anyone know of a way to have several different pressures available to one cylinder? We thought of an electronic regulator but could not find one for sale. Anyone have any ideas?
Well...here again we was thinking outside the box same as you...I posted in this thread
There are several key pieces missing from the KOP however to make this happen and I would post questions to GDC if it's legal or not for sure.
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 20-01-2009, 00:25
You know, there are servos that could possibly be adapted for the regulators, and that is legal (see Dave's Q&A reference). There are also flow control fittings that can help.
Unread 21-01-2009, 17:05
Astarties's Avatar
Astarties Astarties is offline
Evil Robot Overlord
FRC #2057 (AV Cyber Bulls)
Astarties is on a distinguished road
I am pretty certain different pressures would be impossible because you can't have two different systems coming from one compressor, since it would take multiple regulators set to different settings. The entire system would have pressure equal to the lowest setting on your regulators. If you just want the piston to move slower or faster, adjust the little knob on the plastic atatchment thing for the piston (can't remember what they're called) that the tubing goes into. I hope what I'm trying to say is clear enough to understand, I know what I want to say, but putting it to words is sometime hard for me.
"Stand tall and shake the heavens!"
"Never tell people how to do things. Tell them what to do, and they will surprise you with their ingenuity." - General George Smith Patton, Jr.
By the prickling of my thumbs, something wicked, this way comes. Open Locks, whoever knocks!
"Never hold discussions with the monkey when the organ grinder is in the room."- Winston Churchill
Unread 21-01-2009, 17:55
JHSmentor's Avatar
JHSmentor JHSmentor is offline
AKA: Bryan Molloseau
FRC #3210 (Falcons)
JHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to allJHSmentor is a name known to all
The overall intention (at least with our team) would be to have the flexibility to change the pressure released to the piston under different conditions. Using the control valves to slow them down isn't really the same thing in this case. Actuating the piston at 60psi vs. actuating the piston at 45psi and switching between the two or variable between the two would be ideal.
Unread 21-01-2009, 23:35
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
I just posted a powerpoint sketch of a possible solution.
Check the white papers under my name.
I am not sure it will work, but it could be a solution.
EDIT - Made a revision to the layout, see Rev A.
(original sketch deleted)
Good Luck.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 22-01-2009, 08:18
You may be looking for a method to connect the variable regulator to a motor for pressure control. The servo would only give a fraction of a single rotation which is a very small change in overall pressure. However, the rule against modification of pneumatic components seems to come into play. I would think a question to the Q&A about the legality of attaching (as in gluing) a gear to the variable regulator might be appropriate. However, please keep in mind that the valves generally stop sealing at 20 PSI so that limits your secondary pressure range. Remember that 60PSI is the working pressure you must maintain ahead of any secondary pressure changes.
Unread 22-01-2009, 14:39
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The GDC has said on the Q&A that continuous rotation servos which meet the torque and rotation speed specs of the rules are allowed this year.
http://forums.usfirst.org/showthread.php?t=11379
I have no idea if this would be easier or harder than interfacing with a motor, just throwing it out there.
Unread 22-01-2009, 14:44
Kevin,
Maybe you should send me a PM and let me know what you are trying to do. There may be a better way to accomplish the task.
Unread 24-01-2009, 18:48
Perci321 Perci321 is offline
FRC #1302
Perci321 is an unknown quantity at this point
My team finally determined exactly what we need. We found the exact part on SMC but cannot seem to buy it anywhere. The SMC part number is
VY1100-502N. Any ideas on where to buy one? I have spent hours on google but have yet to find one.
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
Nason Pressure Regulator Calvin_1631 Pneumatics 9 09-02-2006 00:40
Nason pressure regulator...HELP!!! Bob Steele General Forum 0 25-02-2004 16:08
pressure regulator blindguyinanorg Pneumatics 12 20-02-2004 08:54
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
