Old control box
Can we use the control box from last years robot and just
put the new DS and electronics in it. |
Re: Old control box
I don't know what you mean by "control box"
But, yeah pretty sure you can use anything that is either COTS, or custom made, so long as the cRIO and DS are the ones controlling the Disable/Autonomous features as well as the teleop mode. In other words you probably can use whatever electronics you want so long as you do also use the cRIO and DS to control things. |
Re: Old control box
I think the question is about reusing the box they made or used to house the control electronics last year. Without knowing if it was an unmodified COTS case, or a fabricated component, or whatever else it was, it's kind of hard to tell.
This is a good excuse to read the rules about material use in Section 8 and try to understand them. The flowchart helps. (make sure you have the latest revision of the rules, too) The main reason I can't answer the question is because I haven't spent enough time studying this part of the rules myself, and would probably give the wrong answer based on what we could do last year...and a lot of things have changed since then |
Re: Old control box
This is something that you will need to ask Q&A. Here's my reasoning (and it won't be easy to follow, because the rules aren't):
1. The definition of ROBOT: "A FIRST ROBOT is a remotely operated vehicle designed and built by a FIRST Robotic Competition team to perform specific tasks when competing in the 2009 competition Lunacy. The ROBOT must include all the basic systems required to be an active participant in the game power, communications, control, mobility, and actuation. The ROBOT implementation must obviously follow a design approach intended to play the 2009 FRC game (e.g. a box of unassembled parts placed on the field, or a ROBOT designed to play a different game, would not satisfy this definition)." This specifies that the control system is a part of determining what is a robot. 2. "<R11-A> Exception: solely for the purposes of determining compliance with the weight and volume limitations, these items are NOT considered part of the ROBOT and are NOT included in the weight and volume assessment: ... The OPERATOR CONSOLE." I read the above to mean that the operator console is part of the robot, except weight and volume checks. 3. However, materials for an operator console are not included in the cost accounting (<R22>). So, it seems that the operator console is counted as part of the robot. After all, it is part of the control system. The wording of <R11-A> seems to indicate that its exceptions to <R11> are only for weight and volume. But the console isn't in the cost accounting. Ask Q&A to be sure, but I think you'll need to rebuild the operator console this year. If it's unmodified COTS, you're fine, but if not, rebuild is your safest option. |
Re: Old control box
We need more information about the control box. If it is not a COTS part then refer to rule R24.
Or you can reference the simpler explanation of rule R33. Quote:
#7
Re: Old control box
I've got a hard time believing that that's what was intended (technical common sense and all that). All the same, you'd think that a clear, airtight definition of a robot might have been a useful thing to include. |
#8
Re: Old control box
Re: Old control box
Give them some credit, though--this year's definition of robot is more airtight than last year's. You're right, Tristan. I think that they need some independent review to help find and clarify this sort of thing. The problem is doing that and ensuring that no details leak. |
#10
Re: Old control box
k thanks
| control box | cloud_254 | Technical Discussion | 2 | 13-02-2008 19:05 |
| Control Box Dimensions | Zultraranger | General Forum | 7 | 11-02-2008 21:41 |
| Custom Control Box | D.Viddy | Programming | 3 | 15-02-2003 11:35 |
| Box Control | Tton | General Forum | 2 | 12-02-2003 23:38 |
| control box | archiver | 2000 | 8 | 24-06-2002 00:20 |
