Go to Post Coaxial swerve modules with a suspension and differential aren't normal. But on Winnovation they are. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 19-01-2009, 13:07
jujuninja's Avatar
jujuninja jujuninja is offline
AKA: Dakota
FRC #1569 (Haywire)
Team Role: CAD
jujuninja is an unknown quantity at this point
Edit Imports
hey how can i edit imports from andymarks mainly the c-base????
Kit Of Parts: $6,000
Buy Food for Those Late Nights: $150
Paying for the bus ride to Atalanta: $400
Loving the Blood, Sweat, Tears for Being On a F.I.R.S.T. Robotics Team: Priceless
e
Unread 20-01-2009, 12:15
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: Edit Imports
Are you using SolidWorks?
You should be able to start a sketch on any plane on any part & make holes (or other extruded cuts) in the parts easily as you would any part, you just can't go back & edit a feature as you would with a part you started from scratch with a full feature tree.
What exactly are you trying to do?
Unread 20-01-2009, 13:07
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Edit Imports
Can you use the import wizard to turn on feature recognition?
I was having a problem earlier last week downloading timing belt sprocket models from SDP-SI as .stp files; every sprocket only had three teeth. Since they were dumb solids, I wasn't able to really do anything easy to fix them. When I went back and downloaded the Pro/E part file, I was able to import that with feature recognition, and it recognized the teeth profile as a circle pattern, which I was able to edit and fill in all the remaining teeth.
Art Dutra IV
世上无难事,只怕有心人.
Unread 21-01-2009, 07:08
mplanchard mplanchard is offline
Marie Planchard, SolidWorks
mplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond reputemplanchard has a reputation beyond repute
Re: Edit Imports
Sometimes with imported geometry the sketches of each feature are "fixed". You have to delete the fixed state from the sketch and then add dimensions that can be modified. The chassis on 3dcontentcentral will download each part of the frame. Edit the sketches and you will be able to make the frame shorter. Marie
Edit Easy C Templates pts211 Programming 1 24-11-2008 14:12
can't edit drawing dimensions AdamHeard Inventor 12 22-10-2007 15:14
Edit whitepaper rbayer CD Forum Support 5 03-10-2002 18:11
Edit Error Jack CD Forum Support 1 29-08-2002 22:02
