Go to Post Sweeeetttt.....Thats all that needs to be said. :D - george56 [more]
Unread 19-01-2009, 21:02
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Have you burned your reciver?
my team(3038) and i could not find the connector for the reviver to the power distribution board. we search for at least an hour so we decided to cut the charger wire and hook it right up to the 20 slot in the power distribution board. It no longer works. does anyone know how to fix it or where to get a cheap one?
Unread 19-01-2009, 21:07
laultima laultima is offline
FRC #1458 (Danvillans)
laultima is on a distinguished road
Send a message via AIM to laultima
Re: Have you burned your reciver?
Do you mean the black Linksys Wireless Bridge? That ones supposed to be plugged into the dedicated 12V port on the bottom of the PDB. And if it turns out you did fry it, they dont seem to be cheap, Amazon has them for $90
http://www.amazon.com/Linksys-Dual-B.../dp/B0010TEOLQ
2007 Davis/Sacramento Regional Winner (100, 997, 1458)
2008 Davis/Sacramento Regional Gracious Professionalism Award Winner
Unread 19-01-2009, 21:12
BradFerg BradFerg is offline
FRC #2705 (We Robot)
BradFerg is an unknown quantity at this point
Did you verify the polarity before attaching it? You should check it with a multimeter. It's a 12V device, so it should have been fine if the polarity was correct.
Google price search:
http://www.google.com/products/catal...989#ps-sellers
Best Buy looks like a good bet for picking it up locally.
Unread 19-01-2009, 22:39
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
After you did this, did you find the CORRECT connector? Do you know to cut off the end near the adaptor (that came with the game adapter) and attach the the connector that is on the end of the distribution board?
-Mike AA
Unread 19-01-2009, 22:51
RoboTigers1796 RoboTigers1796 is offline
FRC #1796 (RoboTigers)
RoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of lightRoboTigers1796 is a glorious beacon of light
What about the AC wall adapter for the bridge. We broke the tip of ours and its beyond fixing with some soldering. Anyone know where to pick one up that will work with the linksys bridge? Also the dedicated 12v connector is included with the KoP? Because we never saw it, only the larger ones for like the axis camera.
Unread 19-01-2009, 22:56
it is definitely fried. we are a new team and got to excited because we have been trouble shooting for about 16hrs, so we could not wait and stuck it in the 20 volt on and it did not work like i said. we rewired it with the wall charger and plunged it in nothing happened. So seriously there is no way to fix it we have to buy a new one for $100? Linksys will not donate another one or first will not supply one?
Unread 19-01-2009, 22:59
Mike AA's Avatar
AKA: Mike Aalderink
Bring the adapter to any local electronics store that had multiple power supplies and find one that has the right size bonnector and just cut off the end near the adapter. The 12V connector is the same as the one you would use for the camera and the breakout boards.
-Mike AA
Unread 19-01-2009, 23:00
ROFLcopter's Avatar
ROFLcopter ROFLcopter is offline
who was phone
AKA: Robert Grizzell
FRC #2364 (Oregon RoboHawks)
ROFLcopter is on a distinguished road
Send a message via AIM to ROFLcopter Send a message via MSN to ROFLcopter Send a message via Yahoo to ROFLcopter
I can almost guarantee you that they won't. US First was the purchaser of the Bridge, so they own the warranty. You going to have to buy another one.'
And just to let you know, the side of the power cable with the white stripes in positive. I would hate to see you fry another.
This signature has been removed in accordance with City Ordnance law L34.B3. If you feel this signature has been mistakenly removed for reasons not within the guidelines of L34.B3. Visit the City Courthouse #3 and file a report.
Unread 19-01-2009, 23:40
If you mean you broke the barrel connector that plugs into the bridge, then you can find those at Radio Shack or other electronic parts stores.
The bridge gets wired to one of the white wago connectors that came in the kit and plugs into the Power Distribution panel to the left of the 24v cRIO power connector.
The Axis camera does not use one of the loose wago connectors that came in the KOP. Instead, it connects directly into the special 5v plug built permanently into the Power Distribution panel located to the right of the 24v cRIO power connector.
Unread 19-01-2009, 23:48
repairmanray repairmanray is offline
repairmanray can only hope to improve
If I understand correctly, you plugged it into 20 volts? If so, it may be possible for you to take it to a repair shop, or find someone who knows electronics who can repair it. It may just be a burned up voltage regulator.
Like all great art, it appears simple, until you try it.
Unread 20-01-2009, 11:55
This may very well be a $90 lesson in reading the manual first. Please read section 3.2 of the FRC Control System manual so you do not destroy your replacement bridge.
However, do not be so hasty in assuming that all hope is lost. I have reverse biased the WGA600N adapter without destroying it. I have also pushed 24V into it without destroying it. However, I might have just been lucky, and I do not recommend doing either. I performed both of these tests using the regulated supplies on the PD, hooking it direct to your battery through a 20A breaker might have blown something - I really don't know, and I really don't have the extra bridges to find out.
In short, go read those sections, hook it up correctly, and see if it works.
Unread 20-01-2009, 13:31
keen101's Avatar
keen101 keen101 is offline
Ubuntu Linux User
keen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the roughkeen101 is a jewel in the rough
http://forums.usfirst.org/showthread.php?t=10842
also, this link shows how to connect things. Could be helpful in the future. Be sure to alway's consult the rules.
http://usfirst.org/uploadedFiles/200...%20diargam.pdf
Unread 20-01-2009, 17:19
okay one more time
We hooked up to the 20 volt slot
my dad is bring it to a guy that can take a computer complty apart and put it back together sometimes better than new
Unread 20-01-2009, 17:28
There is no 20V slot. There is a 24V, a 12V, a 5V and a bunch of unregulated ones. What does the connector's silk screen say?
Unread 20-01-2009, 18:29
okay i do not know where we plugged it in but it was in a slot that said 30volts right next to it and we put in a 20volt breaker. sorry i am a programmer not an electrician.
What Do You Wish You Would Have Known Your Rookie Year? SlaminSwimster General Forum 77 16-12-2008 12:13
What do you call a sale at your house of items that you have? Elgin Clock Chit-Chat 52 07-06-2005 17:44
Have you named your robot? Modeish General Forum 123 13-03-2005 08:27
Have you found your TIER? Rich Wong General Forum 2 30-10-2003 18:53
Have you seen your robot...yet? Steve Yasick General Forum 9 01-05-2003 19:53
