Go to Post Define "surgery". I think we have enough close calls with "surgery" as it is. Thank god for disable dongles. - geeknerd99 [more]
Unread 20-01-2009, 14:11
writchie writchie is offline
Engineering Mentor
AKA: Wally Ritchie
FRC #2152 (Team Daytona)
writchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond reputewritchie has a reputation beyond repute
Re: Flipped Trailer
Originally Posted by ScottOliveira View Post
.... but I'm not sure if they had the swivel hitch installed (which is necessary for the trailer to flip without the entire robot going over as well).
If you examine the latest drawings closely you will find that the swivel hitch is pinned so the trailer and robot share the same fate as far as tipping is concerned.
Unread 20-01-2009, 14:18
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Re: Flipped Trailer
it is far more likely the trailer will just slide rather than flip perk to having no friction.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
Unread 20-01-2009, 14:41
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Re: Flipped Trailer
I hadn't looked at the drawing enough, apparently. Upon further examination it seems you are quite correct. This means that the likelihood of the trailer flipping depends on the likelihood of your entire robot going. Any robot with a high center of gravity will be more likely to have their entire robot and trailer combo go.
I think this also raises an interesting question - in the event of an accidental trailer flip, how are balls that fall out scored? Rule G25.1 states:
<G25.1> De-scoring GAME PIECES – Once a GAME PIECE has been SCORED, it may not be intentionally de-scored (e.g. removed from the TRAILER). De-scoring a GAME PIECE will cause a PENALTY to be assigned. At the end of the match, any intentionally de-scored GAME PIECES will be considered SCORED as originally placed. GAME PIECES that are knocked free from tenuous placements as a result of normal game interactions (e.g. a GAME PIECE on top of a pile of MOON ROCKS that completely fill a TRAILER falls off when the TRAILER is bumped) will not be penalized.
Emphasis mine.
If the trailer flip were accidental, would any balls that roll out of the trailer not count? The trailer could be scored by the balls in it when it flipped, but that would prevent further scoring by the other team. If balls that roll out still count, there would be the possibility that a team scores with the same ball twice, by pushing an already scored ball back into the overturned trailer. Any ideas on this?
Unread 20-01-2009, 14:49
Re: Flipped Trailer
I do believe this has already been asked, at least partially, in various forms on Q&A.
http://forums.usfirst.org/showthread.php?t=11243
In case of trailer tips, the score in that trailer is preserved for the rest of the match. Should game pieces come out, they're anybody's to score again.
The question is, can you score in a tipped trailer? Physically, I think it would be possible, based on the definition of scoring. However, I'm not quite sure if a tipped trailer can legally be scored on.
Low-Cost trailer drawings? (was: Trailer) DM7000 General Forum 2 07-01-2009 16:54
pic: 1065 Flipped Michelle Celio Robot Showcase 13 20-02-2006 23:41
Who flipped most robots??? PBoss General Forum 9 11-04-2003 08:57
Flipped? tonyargote Regional Competitions 40 02-04-2003 19:07
